Old 11-21-2024, 08:41 AM
iluv69s iluv69s is offline
Default Fastest ZL-1 ??
Which ZL-1 ran the fastest times back in the day? We’re automatics faster than the 4-speeds?
The Following User Says Thank You to iluv69s For This Useful Post:
PeteLeathersac (11-21-2024)
Attachments - The Supercar Registry ZL-1 #23.PNG webbed block.PNG Dale ZL-1.PNG 469042829_1992617411244277_4193341679801119705_n.jpg
Old 11-21-2024, 04:19 PM
William William is offline
The local guys that raced #7 out of Dale Chev said it ran much stronger with a higher stall converter. The #2 ZL-1 auto in the famous test ran 11.64/122 with open headers and a little Dick Harrell tuning. They tried the 850 DP but it was too hard to launch on the tires they had. No mention of a converter change.
Probably with the same changes, 4-speed was quicker.
The Following 8 Users Say Thank You to William For This Useful Post:
69M22Z (11-22-2024), dykstra (11-21-2024), lycan (11-23-2024), olredalert (11-30-2024), PeteLeathersac (11-21-2024), RPOLS3 (11-21-2024), Tenney (11-22-2024), Z282NV (11-21-2024)
Old 11-22-2024, 11:01 AM
napa68 napa68 is offline
Any idea who drove the Dale car?
Old 11-22-2024, 01:44 PM
Hard to believe, they are still around. HARE was the chief wrench I recently met with. He still had the original air cleaner flange, reunited with the car last month. He ran the ZL-1 engine from it in his '67 Camaro Hare's Hip Hugger race car for a few years. Spent a few hours listening to his memories of those days.
Still has an Orange '69 Z/28, a fixture at Cruise Nite here.
The Following 10 Users Say Thank You to William For This Useful Post:
69M22Z (11-22-2024), dykstra (11-25-2024), JoeC (11-30-2024), lycan (11-23-2024), napa68 (11-25-2024), olredalert (11-26-2024), ragtop (11-23-2024), RPOLS3 (11-25-2024), Stihl (01-31-2025), Tenney (11-24-2024)
Old 11-25-2024, 11:33 PM
Harold is good people. I thought that's who was involved with the car. He is a fascinating guy to listen to
The Following 4 Users Say Thank You to napa68 For This Useful Post:
dykstra (11-26-2024), olredalert (11-26-2024), RPOLS3 (11-26-2024), William (11-27-2024)
Old 11-30-2024, 02:50 PM
JoeC JoeC is offline
Here is a quote from a 1969 article about Bill Jenkins running in SS/C (4 speed)
"Bill Jenkins has been floggin' the ZL-1 Chevy for two weeks now and has managed to run 10.09-138.48 in his single, four-barrel, 2,830-pound Camaro with a stock parts motor!"
heads up Match racing was a popular money maker running with 2x4BB tunnel ram and light weight into 9 sec ETs (in 1969)
Bill had a SS 396 L-78 with a ZL-1 engine
The Following 3 Users Say Thank You to JoeC For This Useful Post:
dykstra (11-30-2024), olredalert (11-30-2024), Stihl (01-31-2025)
Old 11-30-2024, 11:56 PM
Shipping weight for a 4-speed ZL-1 Camaro was 3,325 lbs.
Here's the Gibb/Lafferty #23 ZL-1 with a 10.75 dial-in and possibly some engine mods.
The Following 7 Users Say Thank You to William For This Useful Post:
Carleen (12-02-2024), L78_Nova (12-03-2024), olredalert (12-01-2024), PeteLeathersac (12-01-2024), RPOLS3 (12-02-2024), Stihl (01-31-2025), Tenney (12-01-2024)
Old 12-01-2024, 11:20 AM
RALLY RALLY is online now
I read where Bill Jenkins said the ZL-1 Blocks had core shift and the cylinder bores had a lot of oil ring blow by with bore distortion. They have the steel bore liners. Bill used from i read the Can-Am Blocks for racing which seem to be better.
Old 12-01-2024, 12:13 PM
Many racers moved to the 430" configuration [4.375 x 3.470] which added 300 rpm at the same piston speed as the 427. Saw some docs concerning the change in the Gibb paperwork.
Yes, the blocks had problems on production motor mounts. One attempt to fix it.
The Following User Says Thank You to William For This Useful Post:
Old 12-01-2024, 01:51 PM
It is a bit confusing because Bill J was given some early aluminum blocks that some called "Chaparral" blocks so he can build and test them.
These were 427 4.250in bore and similar to the production ZL-1 block. Some say it was a little stronger then the ZL-1 block but it was legal in NHRA SS/C as it was very close to the ZL-1 block
Bill said the 427 aluminum blocks "moved too much" and would lose power due to loss of ring seal.
He even tried using a water heater rigged to keep the block warm all day at the track so it didn't heat cycle.
I heard Bill talk about this at Carlisle when he was there at a vendor booth and I was able to ask him some questions and get an autographed die cast model of Grumpy's Toy IV.
In 1970, with the new Pro Stock class rules, they allowed the Chevy 430 Can Am block
4.440 in. bore 3.47 in stroke siamese cyls design.
The Chevy 430 was legal in Pro Stock but not legal in SS/C.
The Following 4 Users Say Thank You to JoeC For This Useful Post:
dykstra (12-01-2024), L78_Nova (12-03-2024), olredalert (12-01-2024), PeteLeathersac (12-01-2024)
