Old 08-30-2024, 08:01 PM
iluv69s iluv69s is offline
Just read this whole thread.. My 67 Z had an NOS MO302 and I thought that was cool.. but a real ‘factory’ DZ 302 67 Z-28 ! Love it !
Sweet car !! ����
The Following 4 Users Say Thank You to iluv69s For This Useful Post:
69M22Z (08-30-2024), dykstra (09-06-2024), juliosz (08-30-2024), napa68 (08-31-2024)
  #112
Old 08-31-2024, 07:11 PM
juliosz's Avatar
juliosz juliosz is offline
Originally Posted by LITTLE TOMMIE View Post
just wondering but why didn't GM put a CE replacement motor in the car instead of the DZ replacement
Tommie, check out my post earlier in this thread. It explains how the DZ was swapped in.
https://www.yenko.net/forum/showpost...0&postcount=48
Old 09-05-2024, 10:03 PM
juliosz's Avatar
With only 41k miles on the car, upon closer examination then disassembly, the lower steering column bearing was shot. After some research, it appears the bearing is no longer available but several places sell a retrofitted end piece with new bearing for around $80-$100. So I started looking for a bearing that’s close and found it on Amazon. The OD of the bearing was just a little too big so I used my brake cylinder hone and after about 45 minutes of working the plastic end piece, it fit perfectly.
The Following 5 Users Say Thank You to juliosz For This Useful Post:
69M22Z (09-06-2024), dykstra (09-06-2024), napa68 (09-06-2024), olredalert (09-06-2024), PeteLeathersac (09-07-2024)
  #114
Old 09-05-2024, 11:11 PM
169indy's Avatar
169indy 169indy is offline
Here is What I used:
https://www.ss396.com/camaro/FBK-678.html
The Bearing is encapsulated into the Lower Bearing Housing, I never thought about extracting the Bearing ONLY and re encapsulating it into the housing - If that is even possible. Credit Darrels preservation for turning me onto this option.
I just finished Restoration of my 1968 Z Column
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 6 Users Say Thank You to 169indy For This Useful Post:
big gear head (09-06-2024), dykstra (09-06-2024), Jims69z28 (09-07-2024), olredalert (09-06-2024), PeteLeathersac (09-07-2024), Tenney (09-06-2024)
  #115
Old 09-06-2024, 09:06 PM
juliosz's Avatar
That's exactly what I did. I incorrectly called the lower bearing housing "plastic end piece". I pressed the old bearing out of the lower bearing housing, using a brake cylinder hone I opened it up for the larger OD of the new bearing then pressed the new bearing in. Based on pics of your new bearing housing, it looks identical to mine so thinking Darrels, SS396 and HB City all doing the same as I did only they are likely more efficient at opening up the lower bearing housing to accept the new bearing than I am using the hone. Here's the completed column. I saved the original paint on the interior side of the column. buffed it with some 15 year old Einszett and it came out nice.
The Following 11 Users Say Thank You to juliosz For This Useful Post:
169indy (09-06-2024), 1967Z28 (09-07-2024), 69M22Z (09-06-2024), big gear head (09-07-2024), Dave Rifkin (09-07-2024), dykstra (09-07-2024), napa68 (09-07-2024), olredalert (11-26-2024), PeteLeathersac (09-07-2024), RPOLS3 (09-10-2024), Tenney (09-10-2024)
  #116
Old 11-20-2024, 07:15 PM
juliosz's Avatar
I used the original grille and headlamp trim. They aren't perfect but are still pretty nice so couldn't bring myself to replace them. When I tested the original headlamps, I kept my fingers crossed and for a second I thought they were good, they were not. High beams work, low beams appear to have burnt-out when I powered them up. Bought replacement T3s at Lectric Limited and they work great.
The Following 9 Users Say Thank You to juliosz For This Useful Post:
169indy (11-20-2024), Dave Rifkin (11-21-2024), dykstra (11-20-2024), napa68 (11-21-2024), olredalert (11-26-2024), PeteLeathersac (11-20-2024), RPOLS3 (11-20-2024), Stihl (12-13-2024), Tenney (11-21-2024)
  #117
Old 12-04-2024, 08:52 PM
juliosz's Avatar
Had a few minutes to mess around with Youtube today. Here's the last and best dyno pull from last year:
https://youtu.be/lVOSkblZ1BU
Here's dialing-in timing and idle in-car (open headers):
https://youtube.com/shorts/aUArW_R5l...4La7Tv8LPANC3J
https://youtube.com/shorts/FwqIw_7gi...Ku6zB5oiLnSENw
1967Z28 (12-04-2024), Crush (12-04-2024), dykstra (12-04-2024), napa68 (12-04-2024), Tenney (12-05-2024)
  #118
Old 12-04-2024, 09:25 PM
dykstra's Avatar
dykstra dykstra is offline
Sounds killer!!!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
The Following 2 Users Say Thank You to dykstra For This Useful Post:
juliosz (12-05-2024), Tenney (12-05-2024)
  #119
Old 12-04-2024, 10:07 PM
napa68 napa68 is offline
Killer killer Paul!
The Following 2 Users Say Thank You to napa68 For This Useful Post:
  #120
Old 12-05-2024, 05:14 PM
Tenney Tenney is offline
Makin' the right racket, for sure! (cool clutch 70!!)
The Following User Says Thank You to Tenney For This Useful Post:
