Old 12-13-2024, 12:02 PM
RamAirBirds's Avatar
RamAirBirds RamAirBirds is offline
Default Aluminum Part Original Finish Questions
Doing some Vapor Honing with a local place here....
What is the feeling about original finish / shade for the following Aluminum Parts..
Muncie Trans Case/Tail
Bell Housing
Chevy / Pontiac Aluminum Intake
Alternator
Distributor
All of these must have been cast with possibly different Aluminum compositions....I guess....But would they all have the same "SHEEN".
I feel I have seen nice original Bell Housings that appear more "shiny / polished that the other parts.
I feel I have seen original Alternators and may distributors that are "Darker" than Muncies or Intakes etc...
Many people are moving towards Vapor Honing for Finish and my firsthand experience is very positive with the outcome. Media Size and such can deliver different results. Trying to get some real info...ANY INPUT IS WELCOME...This Thread may serve to help others down the road.....
Thanks SCR Community for any thoughts or examples.....
The Following User Says Thank You to RamAirBirds For This Useful Post:
napa68 (12-21-2024)
Attachments - The Supercar Registry MuncieTailhousing.jpg MuncieSideCover.jpg MuncieSideCover.a.JPG MuncieCaseShotBlasted.jpg
Old 12-13-2024, 09:33 PM
CamarosRus CamarosRus is online now
I have zero experience with vapor honing
I do have experience seeing Aluminum Sand Casted Intakes that were Metal Shot Blasted
as they were when mfg at a Foundry
See my alternator cases that were tumbled/shaken in ceramic media..........
Ive also shot blasted Muncie Case (Sand casting) and Tumbled/Shaken Muncie
Tailhousing, Side Cover
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
The Following User Says Thank You to CamarosRus For This Useful Post:
L78_Nova (12-16-2024)
Old 12-13-2024, 10:02 PM
mhm1966 mhm1966 is offline
Do some research on vapor blasting. I am not sure if it's the same as vapor honing.
Old 12-13-2024, 11:52 PM
Yes this is Vapor Honing. Meant to restore the surface not so much for cleaning.
The Following 2 Users Say Thank You to RamAirBirds For This Useful Post:
L79Chevelle (12-14-2024), mhm1966 (12-14-2024)
Old 12-16-2024, 04:39 AM
Kurt S Kurt S is offline
It matters if it's a diecast part or a sand cast part, very different finishes.
Most smaller parts are diecast and will have a smoother finish (because they were cast in a steel mold).
The trans maincase was a sand cast part.
Kurt S - CRG
The Following 2 Users Say Thank You to Kurt S For This Useful Post:
FTC (12-19-2024), SS427 (12-16-2024)
Old 12-19-2024, 12:45 PM
yes Kurt, makes a lot of sense. The Bell Housing should be sand cast but many originals look almost polished...
Old 12-19-2024, 04:33 PM
I may be wrong, but I believe bell housings are die cast. Heads, intake manifolds and Muncie main cases are sand cast.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
CamarosRus (12-19-2024), scuncio (12-20-2024)
Old 12-20-2024, 06:38 PM
turbo69bird's Avatar
turbo69bird turbo69bird is offline
I have my own vapor blaster and I can vary the finish.
Sometimes I get a part the way I want it and later I decide I want it just a little less shiny or it’s too dull and I bring it up w a differnt mix or even different amounts of air pressure.
These pictures are from when I first started and I was playing with parts to get the right sheen.
Gives a good idea of the differences.
Trans case is just cleaned vs vapor blasted.
RAIV intake was dull after being, just cleaned vapor blasted half in first pic and then Finished.
Old 12-20-2024, 06:48 PM
Notice it doesn’t smooth out any of the rough casting, it won’t even remove anything silicone. If I need to remove paint I glass bead it first gently to remove the paint then I bring the finish back up w the vapor (honing) blasting. I don’t think there’s any difference between vapor honing and vapor blasting at least not as far as I know. It’s all media in water. Some people add glycol to the mix.
The whole point of it is to roll the media across the finish which closes the surface vs striking the surface and abrading it with some mixes I could polish it like chrome.
The Following 3 Users Say Thank You to turbo69bird For This Useful Post:
mhm1966 (12-20-2024), olredalert (12-20-2024), Tuna Joe (12-21-2024)
Old 12-21-2024, 12:49 PM
jl8z28 jl8z28 is offline
Personally i think the vapor blasting is to shiny
