  #34
Old 12-22-2024, 12:25 AM
Steve:
What camshaft are you running?
If not a roller, are you using EDM lifters?
I have two NOS Comp cams #12-107-3 with lifter kits purchased BEFORE CC started having cam lobe issues. However, the lifters are not EDM. I am hesitant to use one of them in my 302 build.
Does anyone know if I can purchase a good, high quality set of EDM lifters that will work fine with the CC #12-107-3 camshaft? Jerry M swears by this cam (at least the ones made before 2009), and uses it in his D/Stock 67 Z/28, which runs 10.40. Pretty hard to argue with those results, especially considering the heads aren't ported. But he does run headers.
