Old 02-13-2025, 02:06 PM
lpar1969 lpar1969 is offline
Yenko Premier Member
Default Acceptable Date Code for Starters
If the build date of a car is 10D and the motor build date is October 08th, would a starter with Oct 30th be acceptable for restoration
Attachments - The Supercar Registry olebluealtdate.jpg ole blue cowl tag.jpg obstarterdate.jpg obpbdate bluepaint.jpg
Old 02-13-2025, 03:05 PM
X66 714's Avatar
X66 714 X66 714 is online now
What is the assm date of the car? 10D was the projected date. Usually Delco fell a month or so behind. What other known correct Delco items do you have on the car? Alternator, Voltage Regulator, Ignition switch or Distutor even though it was installed during engine assm, could give you clues as to where Delco was at....Joe
lpar1969 (02-13-2025)
Old 02-13-2025, 03:09 PM
Joe
I will check the voltage regulator or ignition switch but outside of that no distributor. The booster is 267 day of 1969 and master cylinder in 262 day of 1969
Lou
Old 02-13-2025, 04:19 PM
What car?,what year?,what assembly plant?, because they all matter in determining this.
The Following 2 Users Say Thank You to Mr70 For This Useful Post:
lpar1969 (02-13-2025), X66 714 (02-13-2025)
Old 02-13-2025, 04:22 PM
I think I'd be looking for a starter with a late September - mid October date.
Bill Pritchard
Old 02-13-2025, 04:56 PM
1969 Z/28 Build Date 10D out of Norwood Plant
Old 02-13-2025, 06:30 PM
Starters were installed after the engine stamped date.Delco-Remy had an ornament plant less than 4hours away from your Assembly plant,so I too would look for a sooner date than Oct.30.,being as it was in the 5th week of Oct.
Having one from late Aug.1969,up to around October 24th,and not going over that would be more realistic to me.
Old 02-13-2025, 07:06 PM
William William is offline
Starters were installed at Norwood during final assembly. Here's what I have:
9N697xxx Z28 910A 9K6
9N703xxx Z28 910D 9K8
9N705xxx Z28 910E 9K22
9N708xxx Z28 910E 9J16
9N711xxx Z28 911A 9K8
The Following 6 Users Say Thank You to William For This Useful Post:
bergy (02-13-2025), dykstra (02-14-2025), jerry455 (02-14-2025), lpar1969 (02-13-2025), turbo69bird (02-13-2025), X66 714 (02-13-2025)
Old 02-13-2025, 07:18 PM
Found a 9K16, so I think from what feedback I got that would be fine
The Following User Says Thank You to lpar1969 For This Useful Post:
Old 02-14-2025, 01:45 AM
daveg's Avatar
daveg daveg is offline
Might just be a Camaro dunce but I have questions.
Pics are Delco stuff on a third week Feb 69 Baltimore Chevelle.
Delco is still Delco right?
9K I would think is for a 1970?
Am I missing something here?
Were 1969 Z28 cars being built in Oct 69? I would think Oct 68 makes more sense?
