Go Back   The Supercar Registry > Sponsors > Boulder Motorcar
Old 03-05-2025, 02:14 PM
napa68 napa68 is online now
I'm wrapping up this phase of the detailing. While the distributor was out, a new set of points was in order....
I had an NOS set of intake gaskets stashed away for this car (it had Fel Pro's in it) along with assembly line end seals...
This was reported to be the original 326 water pump that came with the car. The date spread is a little wide IMO (April 66 pump for an August built engine). I had that rebuilt along with a gentle cleaning of the engine compartment. A few details of original components....
A friend of mine had a 1 year only 40433 AC fuel pump. Fred worked his magic on that...
The exhaust manifolds had some type of coating on them, to say nothing for having gaskets installed between the manifolds and the heads. I removed them, cleaned them in the bead blast cabinet, and dusted on a little engine paint where I have noticed it on real low mile examples. I proceeded to then soak the manifolds on Boshield. My experience is they will burn in real nicely and just have some remains of engine paint left. Very thin layer of copper RTV was used between the manifold and the head.
An overall pic of the engine compartment. I am waiting on the original fan clutch to be rebuilt. I sent that out last week to Dan Kirkonnell http://www.kirkconnellcorvettes.com/
And the chassis after cleaning. Last year I had sourced all NOS exhaust for the car....
I have a set of single crimp brake hoses on deck courtesy of Tim Gilmore, along with a set of calipers that are distinct to 65,66, and some real early 67's. I am sending those out to Lonestar Caliper to be sleeved and rebuilt. A couple of them still have the original inspection mark......
Fresh bushings should be in shortly for the shocks. I can get that installed along with a Quanta alternator belt. The original alternator belt came with the car, but that is not looking too healthy. The original water pump / crank belt on the other hand looked really good and is reused.
The Following 15 Users Say Thank You to napa68 For This Useful Post:
67since67 (03-05-2025), 69M22Z (03-08-2025), big gear head (03-05-2025), carnut4life (03-08-2025), cheveslakr (03-05-2025), Crush (03-05-2025), Dave Rifkin (03-08-2025), dykstra (03-05-2025), Hawkeye (03-05-2025), L78_Nova (03-05-2025), Nasblu (06-09-2025), olredalert (03-05-2025), Roger M (03-05-2025), RPOLS3 (03-05-2025), Tenney (03-08-2025)
  #52
Old 03-05-2025, 03:00 PM
67since67's Avatar
I see a Duntov in this car's future...
The Following 3 Users Say Thank You to 67since67 For This Useful Post:
dykstra (03-05-2025), napa68 (03-05-2025), olredalert (03-05-2025)
  #53
Old 03-05-2025, 05:55 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is online now
Love to see you work your magic on these cars Tim - great results as always.
Jake Dykstra
Dykstra Motorsports
napa68 (03-05-2025)
  #54
Old 03-05-2025, 07:37 PM
dykstra's Avatar
dykstra dykstra is offline
Agreed
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
napa68 (03-05-2025)
  #55
Old 03-07-2025, 07:33 PM
I got bored yesterday afternoon, so I pulled the cluster and cleaned it. I left the tach and speedo alone on this one. If it were not for the fact I have plenty of seat time in this car, I would have sent out the speedo and tach like I did in the 66. Got everything else cleaned, rebulbed, and reinstalled today.
The Following 8 Users Say Thank You to napa68 For This Useful Post:
69M22Z (03-08-2025), carnut4life (03-08-2025), Dave Rifkin (03-08-2025), dykstra (03-08-2025), L78_Nova (03-11-2025), olredalert (03-07-2025), RPOLS3 (03-11-2025), Tenney (03-08-2025)
  #56
Old 03-07-2025, 07:56 PM
67since67's Avatar
You can come by my place and be bored any time you want Tim..and use my tools...
napa68 (03-07-2025), olredalert (03-09-2025), RPOLS3 (03-11-2025)
  #57
Old 03-07-2025, 08:58 PM
TimG TimG is offline
I had a "soft" brake pedal on my '67 427 (not the one I bought from Tim) and he walked me through doing a gravity bleed. Man, it worked great, and the pedal is good and firm now. It's an original J56 car and when the pads warm up, the thing will stop wonderfully.
The Following 2 Users Say Thank You to TimG For This Useful Post:
napa68 (03-07-2025), RPOLS3 (03-11-2025)
  #58
Old 03-08-2025, 01:20 AM
69M22Z 69M22Z is offline
Gravity bleeding works great!!
Old 03-11-2025, 03:49 PM
SupremeDeluxe SupremeDeluxe is offline
This car just keeps getting better and better.
The Following 3 Users Say Thank You to SupremeDeluxe For This Useful Post:
dykstra (03-12-2025), napa68 (03-13-2025), RPOLS3 (03-11-2025)
  #60
Old 03-15-2025, 05:07 PM
60sStuff's Avatar
60sStuff 60sStuff is offline
Tim,
You probably have a case of these, but what a cool wall art this would be.
The Following 4 Users Say Thank You to 60sStuff For This Useful Post:
dykstra (03-16-2025), napa68 (03-15-2025), olredalert (05-10-2025), PeteLeathersac (03-15-2025)
