Old 03-11-2025, 05:42 AM
jbtech's Avatar
jbtech jbtech is offline
Here is my draft wiring diagram that will allow me to use the chrome lineloc button in traditional fashion for burnouts.
With the flip of a switch however, I can depress the clutch and hold the brake, the chrome button will only need to be pressed once, and will engage a latching relay that will hold the line loc and launch rpm limiter on the Omex clubman. When the clutch is released it will disengage both the line loc and launch rpm limit.
The omex clubman has 2 wires coming out of the box which connects to a normally open switch, when the circuit is closed it activated the 2 step. Other systems simply use a 12 volt feed. Anyway this is the reason for the 3rd relay.
Jose Betancourt
67 Camaro L78
The Following 3 Users Say Thank You to jbtech For This Useful Post:
1967 4K (03-11-2025), dykstra (03-11-2025), Steve Shauger (03-12-2025)
  #432
Old 03-12-2025, 06:07 AM
jbtech's Avatar
Revised wiring diagram using a single 6 pin on off on switch. I am happy about this one because it "hides" any evidence of additional 2 step switches/buttons. I wrote this on on a small paper. The center relay has a jumper from the 85 to 87 just as the first draft but it may be difficult to see.
Jose Betancourt
67 Camaro L78
The Following 2 Users Say Thank You to jbtech For This Useful Post:
1967 4K (03-12-2025), dykstra (03-12-2025)
  #433
Old 03-12-2025, 10:33 AM
dykstra's Avatar
dykstra dykstra is offline
I know I’ve said this in the past, but I love this street warrior!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
The Following 3 Users Say Thank You to dykstra For This Useful Post:
BJCHEV396 (03-13-2025), jbtech (03-12-2025), PeteLeathersac (03-18-2025)
  #434
Old 03-13-2025, 09:34 PM
BJCHEV396's Avatar
I agree....she's been thru the battles but probably won more than she lost and has the scars to prove it!
The Following 2 Users Say Thank You to BJCHEV396 For This Useful Post:
dykstra (03-13-2025), jbtech (03-22-2025)
  #435
Old 03-18-2025, 05:13 AM
169indy's Avatar
169indy 169indy is offline
Jose,
Sincerely, ! Thank YOU !
We Just Adjusted Johns 67 Tach! successfully. Using your TIP
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 3 Users Say Thank You to 169indy For This Useful Post:
69M22Z (03-18-2025), jbtech (03-22-2025), napa68 (03-18-2025)
  #436
Old 03-22-2025, 04:04 AM
jbtech's Avatar
Originally Posted by 169indy View Post
Jose,
Hey glad my post helped but I just followed Jason's @SuperNovaSS tip. Looks like Johns tach needle may rest a tad above zero like mine.
Update: I sent the radio guy a spare radio as the Motorola I originally sent had a bad am tuner gear. I bought a spare radio for about 20 bucks and hoping between the 2 radios I can make one ready to go.
I want to get the radio situated before I do any mocking up of the lineloc/2 step relays behind the dash.
Jose Betancourt
67 Camaro L78
The Following User Says Thank You to jbtech For This Useful Post:
169indy (03-22-2025)
  #437
Old 03-22-2025, 04:23 AM
jbtech's Avatar
All gauge readings are now accurate! The super wide ratio trans is a game changer. I like the starting line ratio yet with the 3.31's I can still cruise to work on the freeway. My morning commute is a little over an hour and I'm enjoying every minute of it. I get the nods, waves, and honks throughout the drive. I'd like to think seeing my car is like a breath of fresh air for the other commuters, at least that's how I feel when I see a cool car on the road.
Jose Betancourt
67 Camaro L78
The Following 7 Users Say Thank You to jbtech For This Useful Post:
1967 4K (03-22-2025), 69M22Z (03-22-2025), carnut4life (03-22-2025), dykstra (03-23-2025), mhurd (04-18-2025), olredalert (04-18-2025), PeteLeathersac (03-22-2025)
  #438
Old 04-18-2025, 03:36 AM
jbtech's Avatar
The cool thing about Cars and Coffee in Seaside is there is a playground next door so my boys enjoy going with me.
Also a pic of my yardart!
No other updates
Jose Betancourt
67 Camaro L78
69Z11Pacer396 (04-24-2025), cook_dw (04-18-2025), dykstra (04-18-2025), gtomike1967 (04-19-2025), mhurd (04-18-2025), olredalert (04-18-2025), SuperNovaSS (04-22-2025)
  #439
Old 04-18-2025, 11:10 AM
dykstra's Avatar
I wish there were more cars like yours Jose at my local cars and coffee!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
jbtech (05-07-2025)
  #440
Old 04-18-2025, 07:40 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
^ hear, hear!
jbtech (05-07-2025)
Tags
1967, 396 ss, l78 camaro
