Old 03-21-2025, 10:47 AM
dykstra's Avatar
dykstra dykstra is offline
Car looks killer John!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
Old 03-21-2025, 12:43 PM
69 Post Sedan's Avatar
I’m running bias ply on all four corners…..if you’re trying to go for “The look”, that’s the only way to go as radials don’t look right.
My combination is 15x4 Cragars-Moroso Drag Special in the front with 15x8-M&H Racemaster in the rear. I’m not positive on the basckspace for the fronts but I don’t think there were a lot of options. The car drives fine except on wide cracks/seams in the road……I have manual steering which helps…..IMO
With that being said, the fronts are not DOT approved but the rear are……I have driven my car a lot like that since 2009 and never been questioned on them. But……if you’re going for plan on using a 4” wide wheel…..I’m assuming that’s not DOT approved either…….?
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
The Following 8 Users Say Thank You to 69 Post Sedan For This Useful Post:
big gear head (03-22-2025), chadk (03-24-2025), cheveslakr (03-26-2025), DW31S (04-06-2025), dykstra (03-22-2025), napa68 (03-21-2025), NorCam (03-22-2025), SMS (04-17-2025)
  #13
Old 03-21-2025, 01:18 PM
GrumpyJeff's Avatar
GrumpyJeff GrumpyJeff is offline
M&H used to make a nice DOT "Muscle Car'' Front tire 185/85 27" tall, last time I looked availability was a issue tho, Still have a pair on the front of my Chevelle and my Boss.
Old 03-21-2025, 01:28 PM
Derek69SS Derek69SS is offline
Originally Posted by GaryC View Post
What backspacing are y'all using? I've read 2" on up. The skinnies I plan on using are 1 1/2" BS. If I go bias ply the tire shouldn't balloon like the radial tire if what I'm reading online is correct
The ones on my '68 Chevelle are 5" with 2.5" backspace, so the extra inch is all to the inside compared to yours.
I can't imagine you'd have any fitment problems with the backspace. I've actually been considering putting a 1/2" spacer on mine just to move them outboard a little to match up to the rears a little better. From some angles, they look like they sit way in the fender opening.
The Following 2 Users Say Thank You to Derek69SS For This Useful Post:
dykstra (03-22-2025), GaryC (03-21-2025)
  #15
Old 03-21-2025, 06:53 PM
GaryC's Avatar
GaryC GaryC is offline
That's why I'm asking the BS question. How far OUTSIDE is too far? There are a lot of tires out there and I have noted from 165/80, 165/70, 195/75, 205/70, 205/65, 205/75 and some of the tires y'all mentioned.
Curious what the tallest would be for the 69 Camaro at the front well. My car is already low, Z28, with 235/60/R15 with 15x7 Vintage Wheel Works V40 version of TT II's and they fill the wells good. I'm ready to go for a different look. Going day two. I want to go with a 15x8 rally 4.50 BS and something that will fit for the rear. The rear tires are a no brainer L60 or 275R. Sure seems to be a 50/50 thing with who is running what tire.
Gary
The Following User Says Thank You to GaryC For This Useful Post:
  #16
Old 03-21-2025, 06:55 PM
GaryC's Avatar
Thanks guys for the back and forth on this, it sure will help with my decision.
Gary
Old 03-21-2025, 07:54 PM
GrumpyJeff's Avatar
Wheel /Tire combo & sizes Make or Break a Cars Attitude ! Especially a period Day 2 look. Stance is Everything
The Following User Says Thank You to GrumpyJeff For This Useful Post:
DW31S (04-06-2025)
  #18
Old 03-21-2025, 08:28 PM
LetsFNgo's Avatar
LetsFNgo LetsFNgo is online now
5.60-15 Firestones up front on 15x3.5 Fenton Gyros
N50-15 M&H RaceMaster on 15x10 American Racing slot mags
Getting the 5.60’s to air up was a bear and required ether and a torch. But they do look cool. Even if the car has a long ways to go.
AMC weirdo
The Following 2 Users Say Thank You to LetsFNgo For This Useful Post:
dykstra (03-22-2025), GaryC (03-22-2025)
  #19
Old 03-21-2025, 09:00 PM
I ran the Coker Tire 640.15 Firestone Pie Crusts on the yellow Day 2 Camaro with 4" wheels up front and they fit great. There's a shorter version as well (540.15) but they look too small IMO . Tried them on the Green Z28 but didn't like the smaller tires.
Also ran the 640 pie crusts on the Day 2 Nova I rebuilt a few years back and they were awesome on there as well.
The Following 4 Users Say Thank You to NorCam For This Useful Post:
69 Post Sedan (03-22-2025), DW31S (04-06-2025), dykstra (03-22-2025), GaryC (03-22-2025)
  #20
Old 03-22-2025, 12:23 AM
Crush Crush is offline
I ran the Coker Tire 640.15 Firestone Pie Crusts on the yellow Day 2 Camaro with 4" wheels up front and they fit great. There's a shorter version as well (540.15) but they look too small IMO (tried them on the Green Z28 seen below but didn't like the smaller tires).
Also ran the 640 pie crusts on the Day 2 Nova I rebuilt a few years back and they were awesome on there as well. Some pics and a link to the right sized tires below. https://cokertire.com/tires/firestone-640-15.html
Smaller tires including ProTrac 540's. Not enough height I would say.
And below are a couple shots with the 640 tires which are 27" tall and fit nicely with no rubbing at all.
All these cars look sweet! Great job
The Following 3 Users Say Thank You to Crush For This Useful Post:
cheveslakr (03-26-2025), DW31S (04-06-2025), GaryC (03-22-2025)
