Best confirm but if any help, most online info notes ‘66 L72 Pulley #’s as list below from this link… https://www.detroitautomotiverestora...7-425hp-engine ![]() ~ Pete . ‘66 L72… To complete the L72 engine package, below are the other unique parts for this engine (Some parts like the 3872444 Bell Housing are not shown because they were shared with the L35 396 and the L36 427/390HP engines): Distributor (non-transistorized) - 1111100 Carburetor Intake Gasket - 3881847 Air Cleaner, Dual Snorkel - 6421970 Air Cleaner Decal, 427 Flag - 3874904 Air Cleaner Decal, Horsepower Banner, TurboJet 425HP - 3880870 Air Cleaner Stud - 3869954 Air Cleaner Vent Elbow - 3868842 Air Cleaner Vent Hose - 3846122 Flame Arrestor - 3849856 Camshaft - 3863143 Pistons (11.0:1) - Standard - 3888342 - 0.030 over - 3888344 Crankshaft - 3869952, Casting # 6223 Oil Pump - 3876868 ( Replaced by 3904826) Oil Pump Drive Shaft - 3865886 Vacuum Advance - 1115360 Vacuum Advance Tube - 3877640 Intake Manifold Gasket Kit - 3955527 (for Rectangular Port Heads) 8" Harmonic Balancer - 3860010 Timing Chain Cover - 3975941 Fuel Pump - 6416459 (AC Number 40358) Fuel Lines - Pump to Tee: 3886151, Tee Block: 3886153, From Tee to Carb: 3886152 Valve Covers (Drippers) - 3877631 (LH), 3877632 (RH) PCV Valve - 6423438 (CV691C) PCV Hose - 3871298 PCV Hose Clip (at Base of Carb) - 3846117 Choke Coil - 3887148 Choke Rod - 3885070 Idler Pulley Bracket - 3878226 Water Pump Pulley - 3864480 Crank Pulley - 3869978 (casting number) Alternator Pulley - 3844100 Alternator Fan - 3843346 Exhaust Pipe (LH) - 3866523 Exhaust Pipe (RH) - 3866524 Muffler (LH) - 3928215 Muffler (RH) - 3884800 Tailpipe (LH) - 3883697 Tailpipe (RH) - 3883698 Tailpipe Hanger (LH) - 3883693 Tailpipe Hanger (RH) - 3883694 Tailpipe Clamps - 1368195 7000 Tachometer (6000 Red Line)- 6412549 If your L72 had Transistorized Ignition, here are some additional parts that are required 7000 Tachometer (6000 Red Line) - 6412572 Distributor - 1111074 T.I. Module - 1115005 T.I. Coil - 1115210 42 Amp Alternator - 1100696 T.I. Harnesses, Main: 2988218, Extension: 6287841, Ignition Lead: 2986913 .
The Following User Says Thank You to PeteLeathersac For This Useful Post: | ||
L_e_e (03-25-2025) |
