Old 04-07-2025, 02:41 PM
Default Wanted: Leaf Spring Eye Bracket J Clip - 3892755
Looking for NOS J Clips for the front leaf spring eye bracket on a camaro/ nova.
GM Part number 3892755. Must be the factory type with the nut not just the threaded cone. Will take as many as I can find.
Thanks,
Dave
Attachments - The Supercar Registry IMG_1412.jpg IMG_1411.jpg IMG_1410.jpg IMG_1409.jpg
Old 04-07-2025, 04:08 PM
enio45 enio45 is offline
Dave, got a pic of the original?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 04-07-2025, 06:54 PM
Here are pics.
The Following User Says Thank You to 72-SS-L48 For This Useful Post:
enio45 (04-08-2025)
Old 04-08-2025, 12:46 AM
169indy's Avatar
169indy 169indy is online now
For the Sake of discussions. What is the wrench size on the nut flats and then the threads sizing. I wonder if the replacements are inferior to the Orig design? & can a Guy take Cone style and TIG weld a appropriate sized Jam nut in place for a working option.
I cross threaded one of my Origs as the "J" part of the nut was 'Sprung' which lead to miss alignment of the starting thread and caused a problem that I quickly corrected by NOT forcing it and removed and tapped it out and was really careful starting the bolt again.
I might be able to source one or two factory ones if you are in a jam, but the ALL you can take might be a reason to start fabbing these, if the Cone are just a disaster
Jim
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 04-08-2025, 10:32 AM
Clamp the break closed, v groove and weld it. Grind, hand file to finish.
Welding would the same as a butt, small tack and cool between welds until complete. Blast cabinet with medium coarse media and low pressure to give the repair a slight texture.
mhm1966 (04-08-2025)
Old 04-08-2025, 02:47 PM
William William is offline
Here in WI, the nuts break off the clip. The cone style is far better.
Old 04-08-2025, 02:54 PM
Jim
9/16 hex.
Old 04-08-2025, 02:57 PM
This is the result leading me to go back the OEM route with factory j clips.
3 of these clips stripped out way before I could even torque to spec. All by hand. I wouldn’t trust these.
Here’s an example.
Old 04-08-2025, 03:46 PM
well that def is a problem, wonder if different manufactures of these are the problem?
I like the orig style and would probably do a spot weld on each nut to be sure they don't break loose.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 04-08-2025, 04:06 PM
hogdaddy hogdaddy is offline
What torque are you using.
Here is an interesting thread.
https://www.camaros.net/threads/plea...ip-nuts.83635/
67 Convertible T-1
