Old 05-04-2025, 08:38 PM
Steve Shauger's Avatar
Administrator
Default Small Block Chevy Header to head bolts
Looking for recommendation on header to head securing bolts. I've always used the same 7/16 hex head bolts with a small flange. Curious if there are better alternatives. Thanks!
www.yenko.net
www.vintagecertification.com
Old 05-04-2025, 09:27 PM
markjohnson's Avatar
markjohnson markjohnson is online now
ARP reduced head bolts that use a 3/8” wrench are just amazing and will make you hate those ancient 7/16” header bolts! They come in SS or black oxide.
The Following 4 Users Say Thank You to markjohnson For This Useful Post:
1967 4K (05-04-2025), dykstra (05-05-2025), PeteLeathersac (05-05-2025), Steve Shauger (05-05-2025)
Old 05-04-2025, 10:36 PM
KevinW KevinW is offline
Is there a market for those old 7/16 header bolts?
69 327 convertible (driver)
The Following 2 Users Say Thank You to KevinW For This Useful Post:
Old 05-05-2025, 12:31 AM
I have a couple small cans of header bolts around here. I did prefer the 3/8" hex bolts. They are different lengths too and the longer ones held the torque set better, but they ALL need re-tightening 3-4 times after heat cycles. No memory if they came with header sets, or I bought them aftermarket.
Old 05-05-2025, 12:51 AM
1967Z28's Avatar
1967Z28 1967Z28 is offline
Drill the heads for safety wire so they don't loosen.
The Following 2 Users Say Thank You to 1967Z28 For This Useful Post:
dykstra (05-05-2025), Steve Shauger (05-05-2025)
Old 05-05-2025, 01:43 AM
I use ARP stainless steel bolts with 3/8 head. There are also socket head bolts that work better in some applications.
Old 05-05-2025, 04:17 AM
X66 714's Avatar
X66 714 X66 714 is offline
I use Allen headed bolts. Been using them for years with no problems....Joe
69M22Z (05-05-2025)
Old 05-06-2025, 12:58 AM
JohnF JohnF is offline
ARP now makes a 5/16 head.
The Following User Says Thank You to JohnF For This Useful Post:
Thomas (05-06-2025)
Old 05-06-2025, 01:37 PM
Thomas Thomas is offline
That is what I use on my Stock Eliminator.
Once I tighten them, they do not come loose.
And I use Remflex gaskets. I've never had a leak.
Thomas Schilf
'69 Camaro SS, L78, M22, 4.10 Posi
'69 Camaro E/SA
'00 Camaro SS Convertible
'04 Harley FXST
'80 Chevy Blazer (My first new vehicle)
Old 05-06-2025, 01:41 PM
Administrator
I am waiting on the 3/8 bolts and have the Remflex gaskets ready to install. Thanks!
www.yenko.net
