Old 05-15-2025, 10:43 PM
Default Dist Cap ID ????
What is correct DELCO Distrib Cap for 1970 Z28 ???
I have this with Delco - Remy R & PATENT 2769047
AND I also have a similar Black Cap with NO LETTERS/NUMBERS
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Attachments - The Supercar Registry unnamed.jpg unnamed (1).jpg obrcaptop.jpg obrcaptop.jpg
Old 05-15-2025, 10:50 PM
mhm1966 mhm1966 is offline
The 1970 Z/28 would have had the "Delco Remy" "Patent Pending" R distributor cap from the factory. The "Patent" 2769047 and the cap without letters would be a service replacement cap.
1966 Corvette Coupe L79 Mossport Green
1969 Camaro Z/28 Hugger Orange
NCRS #22211
Old 05-15-2025, 11:12 PM
mhm1966, So my above pictured cap is NOT Assy Line Correct !!!!!!!!!!!
and there was Two different service replacement caps ?? One like above
and 2nd .........without any writing ???????
Chuck Sharin
[email protected]
Old 05-16-2025, 01:21 PM
Chuck, the cap you have in the picture is not assembly line correct for a 1970 Z/28. The cap is a later style replacement cap that was used in 1973 production. They made several different versions of this cap. The one you have 2769047 with aluminum contacts, 2769047 R both with aluminum and copper contacts, and some had other letters like T and BH on top of the cap.
NCRS #22211
Old 05-17-2025, 09:56 AM
daveg's Avatar
daveg daveg is offline
early and late "patent pending" caps.
Pic 1 is earlier type. No "R"
Pic 2 is later type with "R".
They are saying you need bottom type.
The Following User Says Thank You to daveg For This Useful Post:
mhm1966 (05-17-2025)
Old 05-17-2025, 03:00 PM
MHM1966, Thank You for your replies...........
Interested to learn what/where is your source of info so as the Camaro Nat'l Judges
will "Believe"
What 1970 GM V-8 engines during what months received which cap ???
and 1971 etc etc...........
Did the " PATENT 2769047 R " not start until 1973 ??? and all 70-72 received
the PATENT PENDING.......
Thanks for your patience, if you have any left
Ive asked Charley Lillard to get a picture of the assy line cap on his former LOW
milage 70 Z............
Chuck Sharin
[email protected]
Old 05-17-2025, 06:06 PM
jerry455 jerry455 is offline
Fantastic information here- especially with the pics.
I have some older Delco caps NIB on the shelf, will investigate what they are for fun. thanks guys!
Old 05-17-2025, 08:22 PM
----Part number 19719244 in a GM restoration box with just Delco-Remy and patent pending would be for what years and vehicle???....Bill S
Old 05-17-2025, 09:02 PM
"Patent Pending" cap is for 1968 and earlier for all GM models.
NCRS #22211
The Following User Says Thank You to mhm1966 For This Useful Post:
olredalert (05-18-2025)
Old 05-18-2025, 09:57 AM
daveg's Avatar
Some cap info in this older thread.
Posts 1,2,3,4,7,8,link in 10,14,18,19,46 and 47.
69 themed but may help some.
https://www.yenko.net/forum/showthread.php?t=179335
