Old 05-22-2025, 12:40 AM
ban617 ban617 is offline
Those ink marks your referring to ,were probably the manufacturer of the gasket material & possibly the thickness..
The Following User Says Thank You to ban617 For This Useful Post:
daveg (05-22-2025)
  #12
Old 05-22-2025, 03:45 AM
daveg's Avatar
daveg daveg is offline
You are likely right and pan rail gaskets are like this also.
No luck so far on finding any but the hunt is on.
Old 06-10-2025, 03:13 AM
daveg's Avatar
Getting closer.
The FP gaskets with "GM" and "Q" have 3/8" holes.
The ones with 5/16" holes have "GM" and "8".
This is obviously a very small database.
Timing cover gasket is same stuff.
Still looking for pan gaskets like this.
Old 06-10-2025, 12:39 PM
napa68 napa68 is offline
Love the work you are doing here Dave
Old 06-10-2025, 02:19 PM
BCreekDave BCreekDave is online now
Looks kind of like Vellumoid gasket material. We used to die cut many of those gaskets a million years ago. All of the dies are long gone though. Might give those guys a call.
Owned since 1978 - First Car
Old 06-10-2025, 02:32 PM
daveg's Avatar
She thinks I am a bit wacko but this digging for stuff- info is fun.
Some must remember the pain with getting pan rails clean if you were the first person to remove a 69 396 oil pan.
Same on the silver valve cover gaskets.
They ended up in a jillion chunks everywhere.
Then you put the rubber ones in and of course leaked.
Old 06-10-2025, 03:29 PM
67since67's Avatar
Wire wheel on the bench grinder is your friend...
Done this at least a thousand times beating warranty flat-rate in the dealership a million years ago.
RPOLS3 (06-13-2025)
  #18
Old 06-12-2025, 04:02 PM
daveg's Avatar
Can put this search to bed now.
Thanks all
Pan gasket time
