Old 10-28-2019, 03:01 AM
Edgemontvillage's Avatar
Originally Posted by enio45 View Post
nice rivot job lloyd!
..I know a guy...
Old 10-28-2019, 03:07 AM
Originally Posted by 302moz View Post
The a arm in the picture has a 67 , 68 dome style ball joint . I thought Lloyd was restoring a 69?
Here are photos of an original ball joint I removed from the car, my 1969 RS/Z. I replaced them with the same style.
Old 10-28-2019, 12:53 PM
When was your car built, Lloyd?
Old 10-28-2019, 01:58 PM
Its a 2B Norwood car.
Old 10-28-2019, 04:20 PM
302moz 302moz is offline
Default Ball joint
Those are not the same . If you clean the grease off you can see the difference. The rivets look good .
Old 10-28-2019, 04:22 PM
Default Ball joint
The picture Lynn posted is the correct 69 ball joint.
Old 10-31-2019, 10:26 PM
Enoch Enoch is offline
Banned
Originally Posted by ALLZS View Post
1969 Camaro upper control arm bushing washer what is the correct plating
Natural steel painted black.
Old 11-10-2019, 11:24 PM
You might like this one better which is what's installed on my 69Z restoration:
The Following User Says Thank You to Edgemontvillage For This Useful Post:
olredalert (06-04-2025)
  #19
Old 11-12-2019, 02:00 AM
Steve Shauger's Avatar
Administrator
Nice detail Lloyd those are the correct 69 assembly line ball joints. John k. Is correct....
www.yenko.net
www.vintagecertification.com
  #20
Old 06-03-2025, 10:59 PM
Lynn has the correct 69 ball joints. The one Lloyd used are later NOS and are different with the (5) five spot welds.
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
