Old 06-18-2025, 09:08 PM
Default Starter Shield Hex Head ID
Need confirmation on the size of this Starter heatshield Hex Head,is 5/16-18 X 5/8 what was used originally?
Attachments - The Supercar Registry obstarter heat shield.jpg obheatshield.jpg obbrokenstudheatshield.jpg heat_shield_bolt.jpg
Old 06-19-2025, 05:18 AM
daveg's Avatar
daveg daveg is offline
Cannot find a good pic of it but it looks like a corner oil pan bolt??
The tube nut is not on rear solenoid screw, but we have it.
Did not take bolt out to check but it has a lip like pan corner bolts.
Old 06-21-2025, 04:52 PM
daveg's Avatar
Shows as part number 9419370.
Punch that number into epay and you will get multiple choices.
Your size is probably right and these "assembly line correct" offerings have a lip like hers.
Cannot verify the head marking as her car is still put away.
Geralds Lemans blue brush paint job on motor- bellhousing sure is catchy!?!
Old 06-22-2025, 04:19 PM
Diamond_Don Diamond_Don is offline
Here is a pretty good picture...
Old 06-22-2025, 05:41 PM
Thanks guys,but still looking for exact dimensions if possible.
