Old 06-26-2025, 05:55 PM
enio45 enio45 is offline
Default COPO painted wheels - sheen?
68/69 copo steel wheels - are the gloss black or some % of gloss?
Appreciate the advise
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-26-2025, 06:20 PM
William William is offline
There was no 'COPO' wheel. The standard wheel for 1969 COPOs 9560 & 9561 was the production 14 x 7 XT code wheel as used on Camaro SS. Painted black with wheel covers, body color with the standard hub cap. They were full-gloss; seen plenty in my day. Rally wheels were more of a satin finish, not much gloss.
1968 Yenko COPOs used Pontiac Rally II wheels, painted Argent.
From John Z's First-Generation Camaro Assembly Process on the CRG site:
Wheel Painting: The wheels were removed from the prime conveyor and placed in another conveyor system that took them through a booth where their faces were sprayed with color wheel enamel, then through an oven, and the conveyor continued to the wheel & tire assembly area where the wheels were picked off.
The Following 2 Users Say Thank You to William For This Useful Post:
Thomas (06-27-2025), X66 714 (06-26-2025)
Old 06-26-2025, 06:32 PM
Thanks for the info........
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
I think Eddie's talking about the back side of the wheel black color.......prior to painting the front side body color.
Jake Dykstra
Dykstra Motorsports
Old 06-26-2025, 06:38 PM
Thanks Jake, I was actually taking of the front, but now that you brought it up, both sides i need advise. I recall on my 68 copo i had body color on the front (XF) wheels.
I have a 68 L78 car we are working on - drum brake car, ordered with wheel covers - however - my question is related to the spare tire rim. We are proceeding with the gloss black for the front of the wheel for sure, however - the rear of the wheel - gloss too??
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
The Following User Says Thank You to enio45 For This Useful Post:
RPOLS3 (06-26-2025)
Old 06-26-2025, 09:52 PM
From John Z's article:
Sheet Metal Painting: All raw parts (wheels, brackets, etc.) and the front end sheet metal (hoods, fenders, lower fender extensions, header panels, front valances, radiator supports, inner fenders, etc.) went through a cleaning, degreasing, and hot phosphate system, then through a flow-coat booth where it was deluged with black primer from all directions and then baked.
The primer dried to a very dull finish.
Old 06-26-2025, 10:01 PM
So, from this description, the whole wheel is black primer, dried to a very dull finish, and the front side has paint applied on top, in a gloss finish (whatever paint is appropriate)
Am i reading this correctly?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-26-2025, 10:15 PM
R68GTO R68GTO is offline
Yes, that is my understanding and how I painted my XT's. Make sure you let body color blow through the holes from front to back. If your painting black it probably won't show as the overspray will probably dry dull vs glossy.
Old 06-26-2025, 10:21 PM
Got it, similar to how we do the YH rally wheels, but they have bigger holes(slots) to let the color come thru.
thank you all for the advise
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
RPOLS3 (06-30-2025)
