Old 07-15-2025, 05:43 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
To save you some searching, it's listed here:
https://www.yenko.net/forum/showthread.php?t=182822
Cheers friends,
Anthony
Old 07-15-2025, 09:08 PM
67since67's Avatar
Originally Posted by Camaro Dave View Post
Where did you get the front seal from?
My old school a/c guy brought it with him. If they are hard to find I can ask him.
Old 07-16-2025, 05:19 AM
parkbrau's Avatar
parkbrau parkbrau is offline
Can't beat R12 for freezing yourself out of the car
I was looking into replacing the seal on my A-6. Never got around to it. While looking I found this:
"Here's a tidbit that a lot of folks aren't aware of. I like to pass it along to guys who have A6 compressors in their cars.
There is a double lip neoprene shaft seal available that will backfit to the A6 compressor. It solves the problem of the old type ceramic/carbon seal seeping oil and getting it all over your hood, inner fender, etc. It's also more reliable than the mechanical seal for refrigerant retention.
The part numbers are ACDelco# 15-30948 or, GM# 2724954 The seal is actually for newer HR6 and V5 compressors, but works great in the A6.
Tom
Go to autoacforum.com and do a search for .a thread titled "GM A-6 Compressors, Rebuilt?" There is an illustration that shows a cutaway of the A6 seal area and tells where to install the seal. It actually fits into the area where the seal "seat" used to sit.
You remove all of the old seal components, install the oring into the seal bore, install the seal, then install the snap ring. You'll only use those 3 parts from the new seal kit. "
That post was on a buick forum.
https://www.carparts.com/a-c-compres...elco/ac1530948
The Following 4 Users Say Thank You to parkbrau For This Useful Post:
69M22Z (Yesterday), Camaro Dave (07-16-2025), dykstra (07-16-2025), ragtop (07-16-2025)
  #14
Old 07-16-2025, 10:52 AM
Thanks for the replies, I am of the same mindset as you guys. Fix the R12 and go. The system is fully charged just have a stuck POA or something else. Will figure it out.
Thanks for the nudge!
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 07-16-2025, 01:07 PM
Burd's Avatar
Burd Burd is offline
Too bad your not in the D, you could use my equip if if don’t have any
I rescued my R12 system, after being empty for 15-20 years. Got a few stock PCs to put back on one day too.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
The Following 2 Users Say Thank You to Burd For This Useful Post:
olredalert (07-16-2025), RPOLS3 (07-16-2025)
