And after the pressure washing, wire brushing and cleaning, they applied the black wool wax. The stuff is a non-petroleum metal preservative. I think it is Lanolin based. They have clear and black. It lasts about two years and then needs to be reapplied. It's mostly for daily drivers in the rust belt areas, but it soaks into the metal and keeps it rust free. The only caveat is having to wear gloves if you are doing anything under the car. That, and waiting a few weeks for it to harden/soak into the underside original undercoating and metal.
BTW, these guys did the frame repair on my 1995 Suburban three years ago. The common rust area in the OBS 4WD truck frames are the sides of the front engine cradle near the steering box, that have no water drain holes. They did an amazing job on the truck so I had them schedule me for the Lincoln, too. While the Lincoln was there they also had a Pontiac Aztek that they were repairing the unibody frame rails on...and at least a half dozen FJ Toyotas in the staging lanes for repairs. One of them was driven up from Florida for the work. Check out their facebook page and you can see the work they do. Amazing stuff! Last edited by njsteve; 07-18-2025 at 02:28 PM. |
The Following 7 Users Say Thank You to njsteve For This Useful Post: | ||
69M22Z (07-18-2025), Dave Rifkin (07-20-2025), dykstra (07-21-2025), mhurd (07-18-2025), olredalert (07-23-2025), PeteLeathersac (07-22-2025), RPOLS3 (07-19-2025) |
Very nice!!
Nice frame work!
This was the front frame repair they did on my K2500 4X4 Suburban in 2023. Just as amazing! Both the inner and outer sections of the frame where the steering box mounts. A completely closed area with no drainage hole but open to water and salt getting in from above. The passenger side (the far easier side to repair) was repaired back in 2016 by another welder who has since retired. I can't say enough about this shop. It is worth the trip if you are looking for someone experienced and actually reasonable in their fabrication rates.
The Following 5 Users Say Thank You to njsteve For This Useful Post: | ||
69M22Z (07-21-2025), Dave Rifkin (07-20-2025), dykstra (07-21-2025), olredalert (07-23-2025), PeteLeathersac (07-22-2025) |
