Old 08-17-2001, 05:15 AM
Rowdy Rat Rowdy Rat is offline
Default Re: '69 Turbo 400 code?
<BLOCKQUOTE><font size="1" face="">quote:</font><HR>My information shows the 1969 427/335HP Chevrolet as getting the CQ Suffix.Not the CY.It states this code for only that L-36 engine.<HR></BLOCKQUOTE>
That certainly makes a lot more sense...
<BLOCKQUOTE><font size="1" face="">quote:</font><HR>The CX was the trans.in the letter dated 7/12/68 in Colvins book.It was used,as the letter states,in 1969 Special Hi-perf Engine Novas,Chevelles,Camaros,Chevrolet,and Corvette.It looks COPO specific and L-72 Impala or Corvette L-71 and up also got it.
I have seen the CX in a 69 COPO chevelle with a 4:10 Posi.I believe it was specific to these rear ratio cars in 1969.
In 1970 the CY was the trans.of choice for the Hi-perf LS-6 engine.All the LS-6 M40 buildsheets have the CY code available with ANY rear ratio.Not just 4:10.Although I think the 1970 Corvette could get the CX still.Any Corvette documentation out there to prove this?
<HR></BLOCKQUOTE>
I've had the opportunity to look at quite a few 1969 Corvettes equipped with the high performance engines (L71, L89, and L88) and automatic transmission. Without exception, they have all had a "CY" code. If "CX" was somehow linked to a 4.10 rear axle ratio, that would certainly explain why the Corvettes didn't receive it. As I mentioned previously, the highest numerical ratio that could be ordered with the big block and automatic transmission was 3.36; the high performance 427s received a "special" differential with its own code of "AX" (or "CAX" depending upon how late in 1969 the car was built). As far as 1970, my understanding is that had the LS7 Corvette gone into production, it would have used the "CY" transmission along with the same "CAX" rear axle (at least the power team chart for 1970 Corvettes show a 3.36 ratio as the "performance" axle with the the LS7/M40 combination).
You and Joe both touched on a possible transmission - rear axle relationship... Could this have determined which was used for a given application?
Regards,
Stan
The Following User Says Thank You to Rowdy Rat For This Useful Post:
Woj (05-04-2025)
Old 08-16-2001, 11:29 PM
William William is offline
Stan, the CX & CY use converter 8626358. They also use the same valve body 8624854, but different control valve assemblies.
CX uses case 8623457, valve assy 8626613.
CY uses case 8626058, valve assy 8626367.
CX & CY have other internal parts not used on other versions. The cases aren't unique.
The Following User Says Thank You to William For This Useful Post:
Woj (05-04-2025)
Old 08-17-2001, 01:42 AM
Ray Morrison Ray Morrison is offline
William,
The casting number on my CY coded 400 is 8623462, the short tail housing is 8624486.
Stan, I still believe the Transmission Identification sheet of 7-12-68 is for the CY code transmission as they came before the CX. Could the X on this document be the reason you think it is for the CX? The Gibb cars were built with a redesigned Turbo 400 for racing purposes. These first redesigned 400's were called experimental automatics (X). These transmissions are believed to be the first automatics built for Chevrolet with a high horsepower, solid lifter engine. According to documents I have, 39 pages of Hydramatic Production Parts list, the CX code was added on 10-25-68, meaning they were built for 69 cars. Would Turbohydramtic have issued this letter this far in advance on building the CX? If any of you have the November 1968 issue of Popular Hot Rodding and the article about the Harrell Novas, notice in this article they refer to the experimental transmission as 69's, however, we now know the Gibb cars were built on the tail end of 68 with these transmissions as a COPO Nova, which was never mentioned in the article. Both the Cy and CX coded transmissions shared likness in that they were built for high performance applications in 68 & 69, L-78's, L-72's, etc. Could some of the extra experimental transmissions have been built for Gibb, or someone else? Since Mark Fuss has a Harrell Nova that is an automatic, Which is not one of the 50 Gibb COPO's, but could Harrell have built his car with one of these? His Nova supports an L-88 engine. How many other Experimental Automatics could have been built for warranty? There are all kinds of questions that are still unanswered?
Ray
Old 08-17-2001, 01:45 AM
William,
Ray
Old 08-17-2001, 12:50 PM
William,
Thanks for posting the part numbers... I certainly appreciate it!
<BLOCKQUOTE><font size="1" face="">quote:</font><HR>Stan, I still believe the Transmission Identification sheet of 7-12-68 is for the CY code transmission as they came before the CX. Could the X on this document be the reason you think it is for the CX?<HR></BLOCKQUOTE>
Ray,
To be honest, I'm not familiar with the document you are referring to and I don't have a whole lot of background information on the Gibb Novas or the special THM 400s so I'll defer to you and others on that topic. My comments referred exclusively to 1969 Corvettes that used the "heavy duty" THM 400. The cars that I have observed have all been "CY" code ranther than the "CX" code used by the 1969 COPO cars.
Regards,
Stan
Old 08-18-2001, 02:35 AM
JoeC JoeC is offline
To sum it up a little, The CY trans was used in 68 69 and 70? The CX trans is 69 427 COPO only? Anyone know of any CX trans in a non-427 COPO car?
Old 08-18-2001, 03:10 AM
Chevy454 Chevy454 is offline
OK, fellas, here is part of the documentation Ray has: 400TH INFO
Old 05-04-2025, 04:25 PM
Woj's Avatar
Woj Woj is offline
I have a CX trans from a 69 Nova L78.
All 69 Turbo 400s that I have seen have a yellow ident tag. No guarantee on that one though.
Also, Grady's 69 Camaro has the VIN stamped on the CX trans at the top of the bell housing. I don't have a picture of it, but the screw driver in these photos shows where I found the VIN on this TH400 Coded CA. FWIW.
Phil Woj
