Old 01-09-2004, 06:18 PM
berger berger is offline
Default 66' heads
does anyone know if 66' 427 heads oval port # 3872702, date code c1166 sounds right for a 450hp yenko (67') , I got achance to pick them up for a grand is that a good deal.
67 Rs modified stormer z28 482cu in.yenko camaro
67 327 camaro
69 SS 396 camaro
Old 01-09-2004, 06:52 PM
Default Re: 66' heads
I'm thinkin you should be lookin for square port heads..
Old 01-09-2004, 07:55 PM
bertfam bertfam is offline
xman,
The 3872702 heads were used on the lower performance engines. I.E. the Corvette 427/390, Chevelle 396/325, etc...
The heads you need are either the 3873858 (for 1966), or the 3904391 (for 1967).
Both of these are square post and would have originally been installed in a HP application, but WHICH one would depend on the build date of your car.
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
CRG Member
Old 01-09-2004, 07:59 PM
Jeff H Jeff H is offline
You want to look for rectangular port heads dated later in the year. Those are mid/late 66 heads. You'll probably want very late 66 heads dated Nov or Dec, or probably early 67 heads. I'd definitely pass on those heads.
Old 01-09-2004, 08:13 PM
SamLBInj SamLBInj is offline
Where are the 66 foot heads
Sam
SamLBInj
69 Z/28 X33D80 72-B
H-D 105 FLSTC
Old 01-09-2004, 09:32 PM
Thanks much.
67 327 camaro
69 SS 396 camaro
Old 01-09-2004, 09:49 PM
That's NOT bargin
Jake is my grandson!!
