Old 01-11-2004, 06:21 PM
Seattle Sam Seattle Sam is offline
Default Re: 69 camaro weight ???
I don't know how it may work in other states, but here in Washington the truck weigh stations leave their scales up and running even when they are closed, to benefit truck drivers who want to make sure they are legal.
Just find a closed weigh station, and you normally have time to weigh each corner, each side, front, rear, and the whole enchilada!
-Sam
Old 01-11-2004, 06:48 PM
68ys8030 68ys8030 is offline
i've heard that the scales here at desoto drags in bradenton florida are about 25 lbs off. i can deal with that . i'm tring to get my car ready for super chevy in february. i added headers ,traction bars and slicks.
i'd like to run the F.A.S.T series eventually but
i'm not going to shoot myself in the foot and go try to run with those guys with a car that i've never had to the track! those guys are good!!! i'll run super chevy then go to exhaust manifolds ,bias plys and other stuff later! those cast iron headed big blocks are sure heavy !
thanks for the help guys!
steve keech sarasota florida
63 split window fuelie
69 z28
financing my 2 sons cars.... 67 fastback mustang and 69 Camaro.
Old 01-12-2004, 05:28 AM
larry_csa larry_csa is offline
I have a book here. It's by Jim Osborn, 1969 camaro facts. It states that a base camaro V8 curb weight is 3145. I would add about 200 to 250 for the big block. I do not think you can get an accurate weight at a grain eleviator or a big truck scale. The reason for this is in the late 80's I started doing a mach up of my car. At this time I would use Allied Van line scales. They would be off 100 to 200lbs in eather direction. Truck scales are designed to weight heavy trucks ( 10,000 and up ) not cars (3,000 to 4,000 lbs) If you have a state inspection(??) station they should have some scales there. Go to a race track scales ther should be with in 50lbs or so. Rob, I'll answer your questions PM.
Thanks Larry
Old 01-16-2004, 01:32 PM
Chevy454 Chevy454 is offline
Re scales: I tend to trust the "certified" scales more than the track scales. I live across the street from the feed store, and see the MoDOT(?) weights/measures periodically checking the scale. It has to be within 10 pounds at any point on the scale, which is somewhere in the neighborhood of 90 feet or so long. No matter where on that 90 feet they put that weight, it had better be within 10 pounds, or they lose their certification. They can also lose their certification by not being "certified" for 5(?) consecutive years...to regain their certification they must then be 100% correct. As I said above, I've seen a range of 400+ pounds using track scales. But having known what my car weighs on a certified scale I now know which track scales are right and which aren't...
Hey Pete: just think, you might have that white car in the 11's by now if you'd have been drinkin' "Lite" all these years!
Old 01-19-2004, 11:28 PM
The variation in scales depends on whether they are buying stuff from you or selling it to you. Our COPO Chevelle weighed 3700 with half a tank of gas. That was on scales belonging to a guy who sells you stuff so it might be a little high.
