Old 05-15-2004, 08:06 AM
68TopStock 68TopStock is offline
Default Removing Chrome Plating
What is the most effective non-destructive way to remove chrome plating? Has anyone had any first hand experience recently?
Old 05-15-2004, 09:45 AM
68z302 68z302 is offline
Default Re: Removing Chrome Plating
I'm pretty sure this can only be done as a reverse process of chroming.
It's not a do it yourself deal without the right equipment.
A chrome shops your best bet.
Rob
'68Z, original drive train
AS1 AO1 D55 J52 U17 U69 Z28
Old 05-15-2004, 05:30 PM
resto4u resto4u is offline
Ken, i think this can be done with a lite acid solution bought at a hardware store. I think i rememeber dennis gilbert did something like this, send him a email. Not sure what kind of acid it was. Roger
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
Old 05-15-2004, 07:51 PM
Roger,
If tht's the case could you PM me with that too?
I didn't think you could do it at home.
The only acid you can get in a hardware, as far as I know, is muratic acid used for etching concrete.
Muratic acid is also unbelievable for removing rust from steel!
Rob
Old 05-15-2004, 08:54 PM
Denis Denis is offline
I use a solution of 3 parts distilled water to 1 part muriatic acid. Takes about 10-15 minutes to take the chrome off. Solution is neutralized with baking soda afterwards.
Make sure you work in a well-ventilated area.
Old 05-15-2004, 08:58 PM
I've done this to Exhaust tips,and it works very well.
Don't ignore Denis's Ventilation & baking soda comment.
Old 05-16-2004, 03:09 AM
Pantera Pantera is offline
I can promice you he won't ignore that tip but once. Those fumes will curl the hair on your head just walking nearby.
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 05-17-2004, 07:57 AM
Denis and others,
Thanks for the info.
