What is the reason for the different color tags? I have seen the same designation tags with different colors??
Thanks ![]()
Carl ![]() |
Carl,
I thought the colors were year specific. Fo rinstance, 1969 THM400 tags were yellow. I believe 1970 tags were a light blue/green color...... Nuch
Are some black??? or do they just look dark?
Thanks ![]()
Carl ![]() |
The tag on the 70 CW coded trans was black....other applications may have used a different color....I have only seen the L78 tags...
wilma
Are some black??? or do they just look dark? Thanks ![]() [/ QUOTE ] I'll check my database and get back to you...... Nuch
Try this for size:
( you need an ebay login for the search engine to work ![]() ebay search for THM tags Nuch
WOW,
Most of those are yellow, listed for lots of diff years!!! Man ??? ![]() ![]() ![]() ![]() ![]()
Carl ![]() |
I am having an issue with my CX tranny...under partial to 1/2 throttle the Nova lights up the tires and shifts firmly into the next gear... but under heavy to full throttle around 5-6k I hear a slight squeal, then the tranny slips before it shifts into 2nd. I know it has and adjustable vacuum mod as I took a few pictures for Tom W...will an adj of this screw in or out fix this? any help out there?
