Old 01-25-2005, 10:30 PM
Tom Hartman Tom Hartman is offline
Default 12 BOLT AXLE CODES
I am trying to figure out what gear ratio came original in my 1969 Camaro 12 bolt. code is as follows
PF 1101G
E
All I have come up with is the gear set is from the Chevrolet Gear and Axle plant and the "E" is for an Eaton psoi trac unit. Any help would be appreciated.
Old 01-25-2005, 10:32 PM
DarrenX33's Avatar
Default Re: 12 BOLT AXLE CODES
PF 3.31:1 Posi
1969 Z28
1972 Corvette
Old 01-25-2005, 10:33 PM
Thanks for the reply, is there a list of the axle codes somewhere?
Old 01-25-2005, 10:53 PM
DarrenX33's Avatar
Here you go.
Axle Codes
1969 Z28
1972 Corvette
Old 01-26-2005, 04:40 PM
Thanks, I would say by the looks of the list I better check my date code, it is probably a '67 12 bolt in my '69 car. I know it is not original, but didn't think about it being a different year.
Old 01-27-2005, 12:56 AM
Kurt S Kurt S is offline
Yup, it a 67 if it's a 12 bolt.
A 69 PF was a 10 bolt.
Kurt S - CRG
Old 01-27-2005, 11:13 PM
I will crawl under that rascal tonight and check the date code.
