Old 08-19-2005, 07:33 AM
Default 15x7 (4" Bolt Circle) MOPAR Rallys WTB:
Need TWO (2) 15x7 Mopar Rallys with 4" Bolt Pattern..........so as I can trade to someone with CL coded wheels for my 70 SS Camaro.....
Yes I can buy them new at Specialty Wheels and other catologs for $123 each, but hoping to find on EBAY or ???
Please advise what your finders fee is upon my purchase from your private source......
Chuck Sharin
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 08-19-2005, 08:02 AM
camarojoe's Avatar
Default Re: 15x7 (4" Bolt Circle) MOPAR Rallys WTB:
Haven't you been looking for those CL wheels for like 2 years? Just buy the 123.00 mopar wheels for the guy and get the CL's already!
PS.. my advice is FREE.
Joe Barr
Old 08-19-2005, 08:26 AM
Joe, Thanks for your free advice.....I always value your timely comments and expertise....I have been looking for many misc items for the past decade to help in the restoration of my dormant projects.......
Almost anything excellent used 70-73 Camaro & ALL N.O.S. (NEW)
1) Original 1970-197? Restorable 14x7 Rally Wheel Stainless Trim Rings W/retaining clips that go over outer edge of wheel(dont bite inside of wheel)
2) Original 1970-74(NOT 2nd Design with Brushed Finish) Z-28 Trim Rings with BLUE painted retaining clips.....that arent bent,warped, dented
3) Black Plastic Air Valve extensions as came on Z-28's Wheels
4) Big Block TCS Solenoid part # ending with "434"
5) 69-70 Misc Smog System Components/ Divertor Valve #?, 434 TCS solenoid, Metal Tubes, Survivor soft hoses,
6) 70-81 4spd Misc Reverse Lockout Linkage Parts(lower rod is aprox 21" long and stamped 0-5618
7) 70-7? Misc ORIGINAL Muffler and Tailpipe Hangar Brackets and Clamps
8) 1970-1973 Original Survivor Chrome Tip Tailpipes
9) 1970-71 Camaro/Nova 14x7 SS wheels....plain jane steel...CL coded..were body colored with Baby Moon Bow Tie Hub Caps....CL code stamped somewhere
10) 1970-72 14x7 Rally Wheel Center METAL(not plastic,unless MINT)caps NOS or Mint Take-Offs (seriously nice)
11) 1970-74 Z-28/70-71 Chevelle SS ORIGINAL "BOWTIE" center caps with raised face/embossed logo...do not want reproductions or newer FLAT surface BowTies
12) 1970-72 ORIGINAL big Block Fan Shroud, One Piece.....
13) 1970 L-34(350hp) Big Block Open element air cleaner or at least BASE
14) 70-73 Front turn signal Housings with good wiring...Standard & Rally Sport
15) 70-73 Front Std Lenses WITH Stainless Edge Bezel(Dont care if Lense is Bad..Want Bezel)
16) Misc Sheetmetal
17) R/S Chrome Grill Surround that goes inside Urathane Nose Piece/even if chrome is bad .....a CHEAP one can be a good core for rechroming, BUT rechroming is expensive on this potmetal/diecast piece
18) Urathane NOSE Only if very solid with NO warpage, no blistering, no looseness, A VERY difficult piece to find used in acceptable condition and NEAR impossible to repair
19) 70-72 Console parts and pieces including the Deluxe int woodgrain shiftplate
20) 70/71 Deluxe interior doorpanels with woodgrain inserts
ALSO need misc fastners, bolts, nuts, screws such as
From all the MANY (EARLY 2nd) Camaros that have been parted out.....dont you have coffee cans and shoe boxes full of.........
1) Differential U -Bolts and HIGH Nuts
2) Differential Mounting T-bolts
3) Leaf Springs Front Eye Bolts, Nuts, Washers
4) Upper Control Arm Mounting Studs, and SPECIAL "squashed" style Lock Nuts
5) Upper Contols Arm End Washers and Nuts
6) Lower Control Arm Frame Mounting Bolts and Nuts
7) Misc E-brake cable hardware
8) ALL Misc frame related Bolts, Screws, Washers such as Steering Box Mounts, Brake Line Clips, Gas Tank Mounting Bolts
9) Misc Front and Rear BRAKE fasteners
10) Special squashed nuts that hold M.C. to Booster and Booster to Firewall
11) ORIGINAL Stainless Head Bumper Bolts that are NOT dented and can be polished
12) ALL misc sheetmetal mounting bolts
13)Misc ORIGINAL engine bolts, from oilpan,timing cover, Alum Intake, Bellhousing, waterpump
I've made arrangements for a double plot at the Tahoma Nat'l Veterans cemetary so as to accommodate my hoard of 70 Camaro junk when I pass..............
Best regards and see ya at SCR8
Chuck Sharin
Chuck Sharin
[email protected]
Old 08-20-2005, 02:48 AM
camarojoe's Avatar
Might get more response in the Parts Wanted section instead of Cars Wanted, although it looks like you almost need a whole car...j/k
Joe Barr
Old 08-21-2005, 06:55 AM
BBIGG BLOCK 396 BBIGG BLOCK 396 is offline
If you can get the 4" bolt pattern rallys for 123.00 with caps and rings you should buy them! If you are waiting on two of them to pop up on e bay for that price or cheaper you are probably going to be waiting another 2 or 3 years! Those are difficult to find in 15" you can find them in 14" but 15" wheels are hard to get.I have some and I will not sell them because I am waiting to get cars to put them on.If you do accidentally find 2 of them by the time you restore them you will have more than $123.00 each in them.It is hard to get just the 4" center caps for under $50.00 each! Just my 2cents worth.All mopar rally wheels seem to be bring premium prices right now.
Bobby Dodson
Old 08-25-2005, 07:25 AM
vintage-whls vintage-whls is offline
Hi Chuck,
I'll sell you some more CL coded wheel for the $123 ea. You can pick up as always. Hey you might even get a chance to look at all the embossed Z28 caps and the pot metal 14" caps and the factory correct Z28 trim rings you've been asking on. You know the #.
See ya
Terry
