Old 04-01-2006, 06:24 AM
67L78conv 67L78conv is offline
Default Re: how many zl1 motors were made
`after owning a couple of the vintage ZL1 blocks / ZL1 motors I think now I would rather own a new block like this one here in the box, wow what a masterpiece. Too bad it's almost twice the money $10.k minimum cdn plus 2 taxes 15% here in Canada from my GM parts dealer.
I was looking on the web at a site that has the new block listed and it is $6,250.00. They seem to have a pretty reasonable price on most of their engines although I only started looking recently.The link is-
http://www.crateenginedepot.com/stor...0-P233C24.aspx
Old 04-01-2006, 06:39 PM
Check with your local dealer. I bought mine for 5050.00 but that was several years ago.
Jake is my grandson!!
Old 04-02-2006, 09:25 AM
Check this out..http://www.sdpc2000.com/catalog/304/...inum-Block.htm
Old 04-02-2006, 05:00 PM
ZL1mike ZL1mike is offline
THANKS that's more like it $4689.95.
mike
Old 04-13-2006, 10:59 AM
Another question if you please.
Can this new ZL-1 block support the use of the later
14011077 heads? Obviously, these heads don't require those
special two inverted lifter valley head bolts.
And while I'm on that subject, can annyone tell me where
you can get the correct head bolts for this monster? I
remember seeing a complete set of NOS ZL-1 head bolts on
eBay two years ago. EXPENSIVE!
Steve
Old 04-16-2006, 05:20 AM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
You will have to go with ARP bolts. They don't have a set for this application, and they don't have studs to fit. You have to measure each bolt-3 different sizes for 074 heads. The new block has deeper threads so the NOS bolts are not the best fit.
1968 Z/28 34,000 mile, born with engine and trans, Shipper, California car, Fathom Blue, deluxe interior, M21, 3.55 Posi
1962 Oldsmobile Jetfire, Factory all Aluminum V8 Turbocharged and Methanol Injected TURBO ROCKET engine, 4 speed Hydramatic, 4 link rear suspension, 3.36 Anti-Spin differential, California car, PS, PB, PW, AC, Jetfire 2 option package.
Old 06-09-2006, 11:24 AM
GMH454 GMH454 is offline
On the original question, can't tell but remember a GM executive and former NCRS president gave me an estimate of 300 +. Probably conservative
Have a block, ex Greenwood. Which has GM stamping on the pad of 1-8880-A, Porterfield gave me copies of some GM notes that indicated similar numbers went to McLaren and think Donahue (have not looked at them in 10 yrs.)This was dated in the 70's and may have been Can Am blocks, but the numbers were in the same range.
People talk about these being sold by GM, personally think most were back doored.
Who would pay the price of a new car, to buy an engine that in Drags was no advantage due to the weight cap, and in A-prod they were not referred to as grenades for nothing.
Remember in a early Vette mag a photo of Greenwood clearing out the last 16 around 76 or 77.
Wish GM had kept better paperwork.
Old 06-09-2006, 10:14 PM
If they had better paperwork it would take away the mystic.
Jason
Old 06-12-2006, 02:15 PM
zl1vette zl1vette is offline
Here is something that I found in another forum. I guess it refers to "production" GM motors only. Don't take this as Gospel of course, but FWIW:
"A total of only ninety (90) ZL1 engines were built: fifty-four (54) in the COPO 9560 manual transmission configuration, thirty-four (34) in the COPO 9560 automatic transmission configuration, one (1) in the COPO 9567 manual transmission configuration, and one (1) in the COPO 9567 automatic transmission configuration for the other prototype Camaro.
"Of those ninety engines, sixty-nine (69) were put in COPO 9560 cars (47 manual, 22 automatic), two (2) were put in 1969 Corvettes, and two (2) were put in the COPO 9567 cars, leaving seventeen (17) crate engines (5 manual, 12 automatic)."
http://www.camaros.net/forum/ultimat...38.html#000000
Old 09-01-2006, 09:45 AM
Kurt S Kurt S is offline
Those are Camaro engine totals. A whole other batch of Vette engines were made (that have the Vette engine codes on them) and lots of bare blocks.
Kurt S - CRG
