Old 08-18-2006, 08:44 AM
Bavss70 Bavss70 is offline
Default Re: R59 Delco battery topper???
Darrell,
After you receive the plastic top you will have to spend quite a bit of time finding a good battery to fit underneath. Most batteries are built up too much around the base of the terminals so that the plastic top won't fit down properly. After a bit of a search, I found one that fit well and had clean plain sides to match the original look.
John.
