Old 03-27-2007, 07:58 AM
1969camarors427's Avatar
1969camarors427 1969camarors427 is offline
Default Weird item found during garage cleanup ?????
During a spring clean-up i found an unusual item in an old box. Has anyone ever heard of a Indusco Dyna Carburator. It has cast into it MFG By Industrial foundry Los Angeles Pat applied for. It is approx. 5 inch diameter and it looks like it bolts between a 2 barrel carb and the manifold. It has a turbine that spins inside the unit that looks like it is used a a forced air induction. There are 2 peices that are screwed together. I have pictures but they are to large to post. Anyone seen one of these. Thanks.
Old 03-27-2007, 09:11 AM
Chris396 Chris396 is offline
Default Re: Weird item found during garage cleanup ?????
Sounds like you found the legendary 100mpg carburetor!
