Old 04-08-2007, 12:15 AM
Tarrytown SS427s Tarrytown SS427s is offline
Default Power steering hose "Insulators"
Hi guys, I am hoping somebody on here can help me out. I am putting the power steering hoses on my 65 Biscayne, but I need the foam/rubber stuff that goes around the hoses where the clamp is. Both lines have it. Does anybody know a place that makes this stuff?
Thanks
Steve
Steve
68 SS427 Custom Coupe 427/385/M21/3:73
68 Impala Custom Coupe 427/425/M21/3:73
68 Biscayne 2 Door 250/3 speed
68 Caprice Estate
68 Camaro SS396 4 speed
Old 04-08-2007, 12:28 AM
3macs1 3macs1 is offline
Default Re: Power steering hose "Insulators"
Hi Steve:
I bought it from GM about 2 years ago.Might be worth a try there first.Came in a two foot length. Not sure of the part number but I can dig and check if need be since I bought extra for the 66.
Joe
Old 04-08-2007, 01:35 AM
Ngtflyr Ngtflyr is offline
Is that the same material that goes around AC hoses on a 69 Camaro? I never have found the piece I need.
Dave
Old 04-08-2007, 02:36 AM
Hi Steve:
Took a quick run to moms since I knew where this was.It is GM group 4.845 part number 367743.It is made by Armstrong called Armaflex 5/8" id x 3/16" nominal wall. If you cannot get it from Gm looks like armstrong still makes it. It comes up as a standard pipe insulation.
Hope this helps Joe
Old 04-08-2007, 02:54 AM
Thanks Joe! That looks like it to me. I will stop by Chevy on Monday.
Thanks again
Steve
Steve
68 Caprice Estate
Old 04-09-2007, 10:38 PM
Unreal Unreal is offline
Look in your Yellow Pages for an industrial insulation supply house. They keep it in stock. Hopefully, they will have the size you need. He'll probably give it to you....especially if he's a car guy.
