Old 07-02-2007, 06:58 PM
John Brown's Avatar
Default Re: Original rear sway bar?? or not.
The Nova bar would work on a 69 Camaro, but it's narrower than the one pictured and uses wider shock mount/spring mounting plates that attach the bar end bushings. Also the upper "links" for the Nova bar attach to stamped brackets that are spot welded to the underside of the trunk floor, not the frame rails.
John Brown
