Go Back   The Supercar Registry > Dealer Specific Discussion > Fred Gibb Chevrolet
  #11
Old 06-13-2008, 08:54 PM
budnate's Avatar
budnate budnate is offline
Default Re: Hood Scoop
Kim, its touch and go from solid to bending...if you are on it with the torch the air movement from the tip will distort the material when it gets loose to bend and harden that way, find your vynal graphic guy and borrow his heat gun, they get smoking hot with not much air flow..or drive over and use mine
cant find my buddy to get the gas mix that is the trick.
I think I'm going to set it on a small metal pipe and heat it with a plumber propane tank. Thanks guys
