Old 08-05-2008, 03:04 AM
1966L72 1966L72 is offline
Default Re: Suggestions; 69Z 302 Engine Rebuild
thank you all for the responses
1970 Chevelle LS6
1969 Camaro Z28
Old 08-05-2008, 03:42 AM
John, If you freshen up the motor to the right specs and so forth you will be in good shape. Most people work on the wrong end of a Z/28. You can keep the hood closed if you are happy with your rebuild and jack the back of the car up. That is where you have to work on the little 302. Minimum of 4:10's and if you have a chance to put an M20 trans in the car better yet. The key to that motor is the gearing. Even 4:56's would be OK on the street! Good luck! Sam
Old 08-05-2008, 05:53 AM
Sam thinking about it I agree, my last 69Z had 4:11 gears with M20 tranny and it was alot stronger through the gears. The trans in my current car is the original M21 with 3:73 gears so with a fresh engine build and upgrade to 4;11 or 4:56 gears the car hopefully will go a long way... thanks
1970 Chevelle LS6
1969 Camaro Z28
Old 08-05-2008, 06:59 AM
Now your talkin!
Old 08-05-2008, 08:31 AM
47Hammer's Avatar
47Hammer 47Hammer is offline
I still like the headers...
Old 08-05-2008, 03:02 PM
drdave69 drdave69 is offline
I agree with the gear change. My first Z/28 had the 4:10 factory gears behind the original M20. After a stock rebuild and jetting the carb according to Jerry M's advise, the car ran very strong.
Dave
1987 Grand National
