Old 09-28-2008, 06:37 PM
Default Re: B/SA N.H.R.A. NATIONAL RECORD SET
What kind of cam and engine work does it take to make that kind of horsepower from a "stock" L78. I'm not up on what is allowed in stock class racing.
Old 09-28-2008, 06:57 PM
This was talked about earlier HERE.
Old 09-29-2008, 02:16 AM
GOOD FRIEND OF MINE STEVE KOPPIEN JUST SET THE B/SA NATIONAL RECORD IN HIS 69 ( COPO BODY CAMARO) WITH THE L78 396 375HP ENGINE AND TURBO 400. RECORD IS 10:16 129.82 MPH. THAT IS FLYING ON 9 INCH TIRES SEE ATTACHMENT
That's really cool!
Old 09-29-2008, 06:45 PM
Chevy454 Chevy454 is offline
Gotta be stock lift cam, but duration/lsa/lca can all be moved around...big power from such a little change. Engine work, well it's a science unto itself! Sweating the details would be putting it mildly...
Old 09-29-2008, 07:07 PM
A Jerico 4 speed and a 538 ring and pinion and the addition of a 3/4 to 1" fuel line also help. The over the counter BB aluminum heads that NHRA certified was a big step to. But just remember they all cheat! Sometime check out where the header bolts to the head. Usually there is a step out for the gasket and flange area..... well look again. Barely enough to hold the gasket flat against the head. I just love seeing those cast iron intake, flat tappet, mush lifter, Q-Jet 350/255 horse novas go 10.80 in G/S.
Old 09-29-2008, 09:01 PM
Last time I looked at Steve's car it had the stock fuel line!! That blew me away. He told me the holley bowls hold enough fuel that you don't need a big line.
Jake is my grandson!!
Old 09-29-2008, 10:02 PM
I don't think I have seen any in the last couple years that were not at least 1/2" to 3/4". Maybe the rule book has a limit for Stock Eliminator, I am not sure. All I know is that even the small HP cars run good. There ain't NO shabs out there anymore! No easy rounds for the Stock/SuperStock guys.
Old 09-29-2008, 10:35 PM
Sam,There is on limit on size in stock. Most have bigger lines . That's what blew me away on Steves car.
Old 09-29-2008, 11:08 PM
Works for him!
Old 09-30-2008, 05:36 AM
I don't know why but it does.
