Old 01-27-2013, 06:31 PM
Andy4639's Avatar
Andy4639 Andy4639 is offline
Default Re: Delco Pleasur-lift air shocks w POWER PAC compress
<span style="color: #FF0000"><span style="font-weight: bold">Well I got the compressor figured out and have it running. I ordered the dual air line hook up today for it so I can run the lines to the bags and up to the cab for the guage. All I need now is a on/off momentary button like a old ford starter are horn button.</span></span>
71 Chevy Truck modified. LS 6.0 LQ4
2008 Tahoe
2011 Chevy Traverse LTZ-2
94 Touring coupe Elderado
2002 S-10 sons truck
Old 01-29-2013, 01:24 AM
Andy4639's Avatar
<span style="color: #FF0000"><span style="font-weight: bold">Worked on the compressor some more today. Got the mounts and all the holes drilled in the crossmember. Got the momentary switch mounted also. Just waiting on the air lines now!</span></span>
<span style="color: #FF0000"><span style="font-weight: bold">While I was under the truck I snaped a couple of the clear diff cover.</span></span>
2008 Tahoe
Old 01-30-2013, 12:03 AM
Andy4639's Avatar
<span style="color: #FF0000"><span style="font-weight: bold">Got it all mounted and wired. All I need are the air lines I ordered for it and it's done.</span></span>
2008 Tahoe
Old 03-22-2013, 05:36 PM
redmanf1 redmanf1 is offline
Nice setup
Old 03-22-2013, 05:41 PM
&quot;Pleasure-Lift&quot; [img]<<GRAEMLIN_URL>>/hmmm.gif[/img] is that what Viagra is for nowadays?
Old 03-22-2013, 07:10 PM
YENKO DEUCE REGISTRY's Avatar
Where did you get the clear diff cover?
Marlin
67 RS Camaro-327/250hp, 2speed Glide, &amp; 3.08 Open (Danny's Ride)
Old 03-23-2013, 03:24 PM
Here's a nice looking sign to accent your option.
http://www.ebay.com/itm/DELCO-PLEASURIZE...=item2323294556
Old 03-30-2013, 07:33 PM
Andy4639's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: YENKO DEUCE REGISTRY</div><div class="ubbcode-body">Where did you get the clear diff cover? </div></div>
<span style="color: #FF0000"><span style="font-weight: bold">Clear gear covers!</span></span>
http://www.hedman.com/CLEARGEARZ-Cle...rential-Covers
2008 Tahoe
Old 04-16-2013, 12:01 AM
Andy4639's Avatar
<span style="color: #FF0000"><span style="font-weight: bold">Well I ended up buying a air bag compressor the air ride compressor didn't have enough PSI to pump the bags up. I will get some pictures as soon as I can.</span></span>
2008 Tahoe
