#11
If you can post some pics (or email them to me), I'll try to help.
#12
Got the pics. As was stated, it's got a gear drive conversion on the pass. side, so a conventional return spring on the primary side will suffice.
I would advise replacing the primary throttle blades, however; whoever drilled bypass holes in them drilled the holes in the wrong place, and unless the carb is going on something with a pretty wild cam, you'll have trouble getting it to idle correctly. |
#13
Thanks for the info..
Would you be able to restore This for me? What other holley model carbs use The same primary blades?? I've only got the one 3 barrell
2023 Silverado (last GM vehicle I am buying!) 2017 impala (wife’s car) 1970 Raylle 350 post coupe (sold) (5 yrs in bodyshop)had enough!!! 1971 442 W 30 holiday coupe automatic . |
#14
Dave;
I replied to your email. The primary blades are the same as an 850, no problem there. Eric |
