Old 11-17-2013, 02:51 PM
daverd daverd is offline
Default 3 barrel holley info
Does any one on the board restore or have gaskets ?for
These? I have found the bowl and jet plate gaskets
It has gear drive
And squirter mods I want to keep it
That way I have found some of the
Gaskets but not all
Thanks Dave
2017 impala (wife’s car)
Old 11-17-2013, 03:09 PM
VintageMusclecar's Avatar
Default Re: 3 barrel holley info
Holley 3-406 kit, still available.
Old 11-17-2013, 05:16 PM
Plowman's Avatar
Plowman Plowman is offline
They may have to make the kit,some times stuff this old is not on the shelf. They may not have one on every shelf in all cities. Hope this helps. Holley 3-406 Kit, I got one {not for sale}. pm me for info.
Old 11-17-2013, 07:41 PM
Thanks
One more question
Carb is missing its secondary
Throttle return spring
I need one that will
Work for it......
Ordered a rebuild kit online ......
Old 11-17-2013, 08:43 PM
Secondary throttle return spring? [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Not sure what you're referring to there.
Old 11-17-2013, 09:07 PM
Plowman's Avatar
Guessing he means one of these.
Old 11-17-2013, 09:15 PM
That spring is for a mechanical secondary carb, there's no provisions to mount it on a vacuum secondary carb. Besides, if the carb is gear drive, the primary &amp; secondary throttle shafts are 1-1 so there should be no need for a secondary return spring. The secondary shaft should close via the gear drive as the primary side closes.
Old 11-17-2013, 11:22 PM
Plowman's Avatar
So the primary spring closes all three barrel for a leak-free seal.
Old 11-17-2013, 11:24 PM
Correct.
Old 11-17-2013, 11:52 PM
I dunno
The guy I bought it from
Told me it needed that spring
( like the one in the picture)
I have never owned a 3 barrel
Holley before ......
So doing this one is
All new to me ....
I remember these holleys
From the guys cars where I grew up
As a kid .....always wanted one ...
