LUK is a Pep Boys unit. I'm putting one in Benjamin's '69 Nova, only because I know he'll toast it while learning to drive a stick.... The replacement unit will be a better quality unit, likely a GM unit since we will run street tires most of the time.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: YENKO DEUCE REGISTRY</div><div class="ubbcode-body">LUK is a Pep Boys unit. I'm putting one in Benjamin's '69 Nova, only because I know he'll toast it while learning to drive a stick.... The replacement unit will be a better quality unit, likely a GM unit since we will run street tires most of the time.</div></div>
Honestly M its better than that. He will not toast a LUK setup. Call the Rep and ask him. Its good quality in a street unit. |
Maybe others already knew but what is the setup? Tires, trans, hp, tq, rear gears launch rpm & shift rpm?
Full bodied 69 Camaro. 650+/-hp 427bbc. 4.10 rear with 28x9 tires. M23 Autogear Muncie 2.56 1st gear.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: turbojet427</div><div class="ubbcode-body">Full bodied 69 Camaro. 650+/-hp 427bbc. 4.10 rear with 28x9 tires. M23 Autogear Muncie 2.56 1st gear. </div></div>
OK, you are way out of LUK territory now. [img]<<GRAEMLIN_URL>>/smile.gif[/img] I have a McLeod Soft Lok in my 650 lb-ft Pontiac and it's rock solid but does chatter a bit on takeoff. Dual disc is a good bet here. |
I like the McLeod Twin Disc clutch. 800-1000hp rating and you can slip it with the organic discs and it holds extremely well at the track. I have used it several times with LS applications for street/strip cars they never had a problem. Could have been due to hydraulic clutch. Other than that I would recommend a Spec Clutch which again have ran on the street and strip and it worked great as well. I havent had a hard grabbing clutch that didnt chatter on the street a little..
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: cook_dw</div><div class="ubbcode-body">I like the McLeod Twin Disc clutch. 800-1000hp rating and you can slip it with the organic discs and it holds extremely well at the track. I have used it several times with LS applications for street/strip cars they never had a problem. Could have been due to hydraulic clutch. Other than that I would recommend a Spec Clutch which again have ran on the street and strip and it worked great as well. I havent had a hard grabbing clutch that didnt chatter on the street a little.. </div></div>
I've got this in my 67 Nova (600hp). Rock solid and great manners. Not Cheap! |
Hayes or Ram diaphram should work.
I'm running a Hays Street/Strip clutch.....it reminds me of the old Borg Warner Brute Force clutch I had in my old Nova. A little heavier on the foot compared to stock.....but IT HOOKS!
4000rpm launch, shifting at 7k with a 3600 pound car. You'd be hard pressed to find someone harder on a clutch than me...... [img]<<GRAEMLIN_URL>>/scholar.gif[/img] [img]<<GRAEMLIN_URL>>/ ![]() Kurt
![]() 1969 SS396 Post Sedan Delivered to Van-T Topeka KS MCACN Day2 Concourse Gold Award 1965 VW El Lobo Dune Buggy built in the mid 70’s for the Iowa Shriners 1968 Schwinn Orange Krate 1969 Schwinn Pea Picker 1968 Schwinn 5-Speed 1970 Schwinn 3-Speed Deluxe 1972 Schwinn 10-Speed Continental 1973 Schwinn 5-Speed Suburban All Original Paint Bikes |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69 Post Sedan</div><div class="ubbcode-body">I'm running a Hays Street/Strip clutch.....it reminds me of the old Borg Warner Brute Force clutch I had in my old Nova. A little heavier on the foot compared to stock.....but IT HOOKS!
4000rpm launch, shifting at 7k with a 3600 pound car. You'd be hard pressed to find someone harder on a clutch than me...... [img]<<GRAEMLIN_URL>>/scholar.gif[/img] [img]<<GRAEMLIN_URL>>/ ![]() Kurt </div></div> This is what I will use on my W-31!! If Kurt can't break it nobody can:-) Ryan
1969 Beaumont 350 Auto White Sold 1969 Beaumont 307 Auto Green Sold 1969 Chevelle SS 396-L35 Auto Blue Sold 1969 Oldsmobile Cutlass 'S' Sports Coupe W31 |
