#11
![]() Quote:
-Second undercoat and Prime -Bake -Wet sanding/Buff -First finish coat -Bake -Second Finish Coat -Bake -Polish (Echoes of Norwood page 96 (GM/FB paint process order flow chart) BUT: the process changed again slightly with the phase in of ELPO and the use of the 50,000 gallon electrostatic prime system In the Pre Elpo era of sprayed undercoat and prime, Buffing was done primarily to remove dirt from the undercoat prior to the first paint coat. After the phase in of ELPO primer the paint process featured the addition of buffing before the final reflow oven. After the reflow oven the unit went to the polish station as normal. The car could also be sanded and buffed again in a final step at an area called Automotive General Repair (AGR). |
The Following User Says Thank You to 70 copo For This Useful Post: | ||
southernfriedcj (06-20-2019) |
#12
Just take a look at an original unrestored car.
You might change your mind about that. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph best |
The Following User Says Thank You to Keith Seymore For This Useful Post: | ||
#13
![]() Quote:
It will probably look like a 1929 paint job because I'll shoot it in my garage. |
#14
![]() Quote:
It made it almost halfway home from the dealership before it locked up. K
#15
![]() Quote:
K http://www.73-87.com/7387info/Assembly%20Line.htm
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph best Last edited by Keith Seymore; 06-20-2019 at 12:16 PM. |
#16
I agree - at the St. Louis Corvette plant, their was a polishing station on the assembly line that all cars went through. No wet sanding except on the repair line as needed.
#17
My black 69 Z/28 received almost no color on the lower 2 inches of the rear valance in one area about 10 inches long.... from the factory.
#18
![]() Quote:
Big signs along the line warning everyone not to touch the units too. ELPO was very sensitive to any foreign matter for the purposes of adhesion control. |
#19
![]() Quote:
GM started using Base/clear first on '82 Corvettes that were tu-toned, it was an enamel clearcoat. Then Corvettes from '84 up all metallic colors used base/clear, some solid colors were still single stage. GM Trucks have always used enamels weather solid or metallic. The last known lacquers were in 1990 on the B-body line. Asian and European produced vehicles first started base/clear in '72 on metallic colors only, once again enamels. Back in the 90's into early 2000's we subcontracted for GM upgrading vehicles bound for the press and media, primarily ensuring the quality of the finish and color uniformity was above and beyond what the assembly line was producing for the general public. This entailed color sanding and buffing, all the way to complete refinishing of the exterior (complete disassembly of trim, glass, etc.) and some times door jambs. GM wanted to give the press and media exceptional cars to write and review about. I would have anywhere from 3 to 7 vehicles at a time, these were then provided to P&M all over the country.
Shaun |
The Following User Says Thank You to galveston For This Useful Post: | ||
PeteLeathersac (06-29-2019) |
#20
![]() Quote:
OP: Here you go and it is a Firebird. This is the polish station on the line. FYI.. I am doing another book next year-again on Norwood and this will be in it so here is a teaser. |
southernfriedcj (06-28-2019) |
