Old 09-20-2022, 05:13 AM
SPEEDYB SPEEDYB is offline
Never knew about the power glide option w/Lm1, wow!
Years ago I bought a 69 LM1 nova with a turbo 350, 3.08 12 bolt,
buckets, console w/gauges,power drum brakes, vinyl top
paid $200 for it because it had a misfire! raced it for years!
The Following 3 Users Say Thank You to SPEEDYB For This Useful Post:
69M22Z (09-20-2022), JBALL (09-20-2022), MosportGreen66 (09-20-2022)
  #12
Old 09-20-2022, 12:14 PM
William William is offline
Originally Posted by L78M22Rag View Post
There’s a DB on LM1 Camaros?
Not that I am aware of. I was referring to the CRG database.
Old 09-20-2022, 04:05 PM
fsc66 fsc66 is offline
Default Lm1/m35
1,612 units built through end of Sept
Paul
[email protected]
Old 09-20-2022, 08:39 PM
----Would the Turbo trans mentioned above be a 400 or a 350 in 69 with the LM1???.....Bill S
Old 09-20-2022, 09:32 PM
TH350. No sb/TH400 in a 1st Gen.
The Following 2 Users Say Thank You to William For This Useful Post:
olredalert (09-21-2022), SPEEDYB (09-23-2022)
  #16
Old 09-21-2022, 12:53 AM
Default LM1/ 3-spd auto
Above combination: 5,412 units
[email protected]
The Following 3 Users Say Thank You to fsc66 For This Useful Post:
olredalert (09-21-2022), PeteLeathersac (09-26-2022), SPEEDYB (09-23-2022)
  #17
Old 09-25-2022, 11:33 PM
BigD69 BigD69 is offline
Default Lm1 pg
I have an all-original matching number 1969 Camaro LM-1 with a powerglide and a 12 bolt. It was built in LA with a 09B build date.
The Following 6 Users Say Thank You to BigD69 For This Useful Post:
69M22Z (09-27-2022), L78M22Rag (09-26-2022), L_e_e (09-26-2022), olredalert (09-26-2022), PeteLeathersac (09-26-2022), R68GTO (10-02-2022)
  #18
Old 10-02-2022, 09:47 AM
69VN's Avatar
69VN 69VN is offline
Maybe this can help...
http://www.camaros.org/lm1.shtml
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
The Following 3 Users Say Thank You to 69VN For This Useful Post:
L_e_e (10-02-2022), olredalert (10-02-2022), ruralrte66 (10-02-2022)
