Old 06-01-2025, 09:28 PM
Default General Engine Question
I'm planning to replace the umbrella type valve seals on my Camaro's 350 small block engine with the engine in the car, because it's oil fouling the plugs on cylinders 6 and 8. I have a plan in my head and I just want to make sure I'm thinking correctly.
I intend to bring the number 1 cylinder up to TDC. At that point, I believe the piston in number 6 cylinder would also be at the top of its stroke, albeit between the exhaust and intake strokes.
I have the tool that screws into the spark plug hole and attaches to compressed air, in order to hold the valves in the closed position. I'm thinking I should be able to replace the seals on both the number 1 and number 6 cylinders at this point. Once that's completed, I plan to rotate the crank 180 degrees and then I should be able to replace seals on cylinders 8 and 5. Another 180 degree rotation to do cylinders 4 and 7, and finally cylinders 3 and 2.
Does that sound logical? I don't want to screw this up and have to pull the heads off. Thanks in advance.
Bill Pritchard
