Old 06-09-2008, 06:59 PM
Default Re: Exhaust Manifold Bolts , Big Block
I agree with what Rick (mr70) said. My car is unrestored (69 SS Chevelle) and when I removed the exhaust manifolds, the non-shouldered bolts were on the inboard ports and the shouldered on the outboard ports. I tried to put the shouldered ones in the inboards and they would not seat. The holes are not deep enough, at least on the heads on my car. The repops that are available today don't match what came on my car.
Hope this helps.
Phil Woj
Phil,
Ok - there are eight bolts per side. If you numbered them
from one to eight ( L to R ), which bolts were of the shouldered type.
Nuch
Old 06-09-2008, 09:06 PM
1969grb 1969grb is offline
Nuch, Shouldered bolts would be 1,2,7,8 non-shouldered would be 3,4,5,6 Grady
Old 06-09-2008, 09:11 PM
bluel78 bluel78 is offline
Did the aluminum heads use the same bolts?
Old 06-09-2008, 11:49 PM
That's a great question on the L/89 application
Nuch
Old 06-09-2008, 11:52 PM
Woj's Avatar
Woj Woj is offline
Nuch,
Grady has answered the numbering question.
As I recall, the ears on the exhaust manifold are are of different thickness by about 1/16". The inboard ears are about 1/16" thicker than the outboard ears.
Phil Woj.
Old 06-12-2008, 02:24 AM
JohnZ JohnZ is offline
Corvette applications used a special bolt with a special self-locking thread form, P/N 3909821, and 3928905 for the location that included a threaded stud. AMK has the 3909821 bolts.
'69 Z/28
Fathom Green
CRG
