Old 06-05-2008, 07:12 AM
1969grb 1969grb is offline
Default Exhaust Manifold Bolts , Big Block
I know I read a post about 69/70 exhaust manifold bolts for big block applications. I am having trouble finding it. Can someone help?
Thanks, Grady
Old 06-05-2008, 08:01 PM
COPO CARTEL COPO CARTEL is offline
Default Re: Exhaust Manifold Bolts , Big Block
Try 427King.... Chuck
Drive it ...Like you STOLE it !!
Old 06-07-2008, 06:10 AM
thehornworks thehornworks is offline
Still available from GM. Gary
Old 06-07-2008, 08:13 AM
Unreal Unreal is offline
There are two exhaust manifold bolts available from GM. However, neither has the head markings that are even close to my originals.
Old 06-07-2008, 10:04 AM
What I was looking for was information on the type of bolts used. I believe that on big blocks there was 8 shouldered bolts and 8 non-shouldered. I believe this was covered in another post but I can not find it. Thanks for everyones input, Grady
Old 06-07-2008, 04:06 PM
-----Grady,,,I know Dick Fortier, the former owner of Paragon Corvette to be probably one of the most knowledgeable guys around about correct bolts for GM usage, specificly Chevrolet. Dick couldnt stay retired and re-started as a restoration bolt supplier. I cant lay my hands on a # or web-site at the moment and am in a crush to get a car ready for Carlisle, but hopefully someone else on here can get you contact info for him........Bill S
Old 06-07-2008, 05:48 PM
Based on what I've seen,most 1969-70 Big Blocks including trucks,came with a longer shouldered bolt on the exhaust port end holes,(bolt #3909830 3/8 X 16 X 2&1/16)..and a shorter non-shouldered non-washered bolt on the inside holes,(bolt #3909821 3/8 X 16 X 1&3/16).
Also remember that what GM recommended an engine assembler to install vs. what that assembler actually did install,were not always the same thing.
Old 06-08-2008, 05:49 AM
Bill, Thanks I had forgot about Dick Fortier. Got the contact info from NCRS. I will contact him next week. Grady
Old 06-08-2008, 07:13 PM
I've heard this from some of the Corvette guys as well.
Nuch
Old 06-09-2008, 02:02 AM
Woj's Avatar
Woj Woj is offline
I agree with what Rick (mr70) said. My car is unrestored (69 SS Chevelle) and when I removed the exhaust manifolds, the non-shouldered bolts were on the inboard ports and the shouldered on the outboard ports. I tried to put the shouldered ones in the inboards and they would not seat. The holes are not deep enough, at least on the heads on my car. The repops that are available today don't match what came on my car.
Hope this helps.
Phil Woj
