Old 07-29-2008, 06:30 AM
COPO 70 RS/Z28 COPO 70 RS/Z28 is offline
Default 70 TH400 SPEEDO GEAR HELP
Does anyone have a reference which can identify the following
ACDelco
GM# 1362196
GR 4.337
LC37
This is supposed to be the right gear for a 1970 3.73 can anyone confirm this.
Thanks
Carl
Old 07-29-2008, 06:36 AM
Default Re: 70 TH400 SPEEDO GEAR HELP
Should be purple with 43 teeth.
Used on alot of vehicles before then,but for 1970:
*1970 Camaro w/TH400 w/3:55 & F70X15 tires.
*1970 Chevelle & Impala series w/TH400 w/3:31 & G78X14 & H78X14 respectively.
The 1970 3:73 TH400 Camaro used #1359273 which was brown with 39 teeth used w/F60X15 tires.
Old 07-29-2008, 07:00 AM
Its purple, I did not count the teeth, its in the bag unopened.
Sounds like the wrong one for the 3.73..
Thanks again for the help Rick
Carl
Old 07-29-2008, 07:10 AM
427.060 427.060 is offline
The gears are still available through your local Chevy dealers. I bought some a few months ago at about $6 each.
James
1968 Beaumont SD396
Old 07-29-2008, 07:21 AM
Excellent
Thanks for the info. If anyone needs the one I have let me know And its yours!
Carl
