Old 08-23-2008, 10:42 PM
Default Need help finding shop for '93 Mustang
I have a '93 5.0 Mustang as my daily driver and was recently told that I need to have new gears and bearings installed in the rear. The Ford dealership wants $1,668.00 to do the install (ouch!). Does anyone know a shop that they'd recommend in the Atlantic City, NJ area for this job and how much should it cost if I supply the gears?
Thanks
Old 08-24-2008, 12:05 AM
JChlupsa JChlupsa is offline
Default Re: Need help finding shop for '93 Mustang
any High School/College Auto Shops in the area. They might take it on with the watchful of the instructor for a grade.
Old 08-24-2008, 02:36 AM
VintageMusclecar's Avatar
What about a boneyard diff?
Lots cheaper.
Eric
Old 08-24-2008, 05:49 AM
Lots cheaper.
Eric
I've thought about that; just afraid I might be getting into the same boat plus I think I might have a hard time finding one with the 3.73:1 gears like I have currently.
Old 08-24-2008, 08:20 PM
njsteve njsteve is offline
I used the Bontempo Brothers Speed Shop, 1539 W Blancke St, Linden, NJ 07036-6219, (908) 862-6336
They have had a speed shop for about 40 years in the same location. It's like walking into a time warp with all the vintage stuff they have hanging on the walls. They specialize in rear differential work.
I had them set up the 10 bolt rear for my 72 T/A. It did cost about $1100. They hot tanked the housing, replaced all the gear and axle bearings, rebuilt the posi unit with new clutches and reinstalled and set up the original 3.42 gears. The days of the $200 gear swap are well past unless you do it yourself.
Remember you always have the time and money to do it right the second time around.
With rear end gears you really need a pro (or someone who knows what they are doing) to install them. You can destroy a new gear set in about 10 seconds.
Old 08-24-2008, 09:44 PM
indyjps indyjps is offline
the 8.8 is a pretty simple rear to set up wtih new gears, depends on how complete of a rebuild you want. Look for some 5.0 gearheads in the area, they probably have some stock gears they'll set you up with, would be a good source to find a personor shop to do the swap.
theres quite a few 5.0 and mustang sites that you could check out to find someone local.
Old 08-25-2008, 12:23 AM
I would try to find a complete rear. I know this one is too far away but this is not the only cheap axle available out there.
http://sfbay.craigslist.org/eby/pts/810782725.html
Jason
Old 08-26-2008, 05:43 AM
Alss's Avatar
Alss Alss is offline
Dave, have a good freind who is a ford master tech..he could do the rear no problem..has done over 200 of them for ford so far...is it in or out of the car?..could be done in my shop if you can get it here
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 08-26-2008, 03:18 PM
ALbert
Albert,
The rear is still in the car; I use the car as my daily driver. I am sure I could get the car to your shop; how much do you think your friend would want with me supplying the parts?
This would be so cool, I could get my car fixed properly and maybe get a glimpse of that beautiful Chevelle you're building.
Thanks for the offer
Old 09-10-2008, 03:53 AM
Alss's Avatar
Dave where ya been..have not heard back from you..still available to do the rear.
ALbert
