Old 08-25-2008, 06:05 PM
JHS JHS is offline
Default L:88 piston ID
Anyone know the TRW/GM part# that should be stamped on the top of a L88 Piston?
'70 L78 NOVA SS
'77 Bronco
Old 08-25-2008, 06:27 PM
Default Re: L:88 piston ID
It looks like the Std. bore TRW/GM 1969 L-88 piston was #3959105,to be used with the "New" #074 Al. head w/118.0 cc.
GM #3959106 was .001 oversized.
GM #3981891 was .005 oversized.
GM #3959107 was .030 oversized.
They list another one,which I think was specific to the 1968 Corvette L-88 which used the #842 Al. Head. w/106.8 cc.
They are:
GM #3909857 was Std. Bore.
GM #3909858 was .001 oversized.
GM #3909859 was .030 oversized.
GM #3909860 was .060 oversized.
Sometimes the last 4 digits are pressed in them.
Old 08-25-2008, 08:45 PM
JHS JHS is offline
Thanks for the info.. I am trying to determine if my car has the L-88 pistons in it without pulling the engine. I have scoped the pistons and they appear to be the big dome ones and have a number (hard to read)stamped into the top of each piston but those numbers you gave me do not match what I THINK I see. The car has open chamber 990 heads on it and a pretty radical cam so I think they are L-88 style.
'70 L78 NOVA SS
'77 Bronco
Old 08-25-2008, 09:15 PM
Born30YrsLate Born30YrsLate is offline
perhaps they are LS-7 pistons...those are dome pistons similar to the L-88s, except for the LS-7 454 engine which also used 990 heads, it got a healthy cam too...just a thought
I don't think it was coincidence that the Great Depression happened during Prohibition...
Old 08-25-2008, 09:17 PM
"and have a number (hard to read)stamped into the top of each piston "
What number do you see?
Old 08-26-2008, 12:53 AM
JHS JHS is offline
Left it at home so will post later. I do know that the pistons do not have an over bore size stamped on top so assume it is a std. bore.
'70 L78 NOVA SS
'77 Bronco
Old 08-27-2008, 04:11 PM
JHS JHS is offline
Here is what I THINK is stamped on top of the pistons:
L2808A. I am unable to get a clear shot at the stampings due to my scope not having an optical extension with a "memory". I can not bend the optic cable in a stationary position in order to get a good view of the lower top side of the piston where the stamp is.
'70 L78 NOVA SS
'77 Bronco
Old 08-27-2008, 08:28 PM
That is a TRW number. If you call them and get the right guy they will sometimes go into the archive and tell you what it is.
Jason
Old 08-27-2008, 08:49 PM
Rixls6 Rixls6 is offline
It's probably an L2308 which is correct for an L88 427. Now it might also have another stamping showing the oversize, like .030 or .060
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 08-27-2008, 09:42 PM
JHS JHS is offline
I went to their web site and pulled up some info. but no number like this. Will give them a call. Thanks.
'70 L78 NOVA SS
'77 Bronco
