Old 09-02-2008, 10:46 PM
Unreal Unreal is offline
Default NGK Spark Plugs
I know this has been discussed before, but I did a search and could not come up with a definitive answer.
What NGK plug should I use in my L72. 840 heads, small dome pistons 9.75:1 static compression. 4346 Carb. Runs on premium pump gas.
Car will be street driven and probably not raced. With my A/C box in the way, it's a PITA to change #8, so I really want something that will last!!
Thanks,
Old 09-02-2008, 10:59 PM
Chevy454 Chevy454 is offline
Default Re: NGK Spark Plugs
R5671-7 (parts guy will probably show 4091)
BTW: click here
Old 09-03-2008, 02:36 AM
Thanks Rob. I knew I had seen it somewhere here, and I searched under your screen name. Somehow I missed it.
Old 09-03-2008, 08:25 PM
No problem...just remember, the "-7" is the heat range, and NGK's run backwards of normal plugs...
Old 09-21-2008, 10:41 PM
Rob,
I went to install the R5671-7 plugs today, and they are the 5/8 hex version, not the 13/16 hex. I guess I shoulda checked them out when I bought them!!
Anyway, if I read your other post correctly, I should either use GR5 (stock 2851) or GR4 (stock 2635)
Did I read correctly? Would you recommend one over the other for my application?
Thanks,
Old 09-21-2008, 11:00 PM
Just called Advanced, and they listed the GR5 for an L72, and have them in stock. Since I dropped my compression to 9.75 to run on pump gas, do I need to go to one range hotter? Would that be GR4?
Old 09-22-2008, 05:57 PM
The 5/8" hex won't matter...in fact, it makes them easier to get a socket on...seems I had 'em listed as 13/16" hex, instead of the correct 5/8", but I fixed it: click
The hotter plug may indeed be better...
Old 09-22-2008, 11:52 PM
Well, the thread diameter was smaller, too. I figured the 5/8 must be for 14mm and the 13/16 for 18mm....not sure about that, but I know I would have needed a LOT of pipe dope to get them to seal!!
Just called Advanced, and they stock the GR4's. Thanks for your help.
Old 09-23-2008, 12:02 AM
Just out of curiosity, did the 291 head, which replaced the 840, use the smaller thread diameter spark plugs?
Old 09-23-2008, 12:06 AM
JRSully JRSully is offline
the 291 used the 840 plug for the early part of the model year, then switched over to the peanut plug
71 Porsche 911 Targa
