Old 11-07-2008, 11:15 PM
bennettracing bennettracing is offline
Default 1969 Camaro Pace Car Z11 396 A/T A/C
Well I didn't want to sell this but to many projects I've had this 69 Pace Car for some time it had been restored about 10 years ago, I started to take it apart and start over to make it more correct. This is a 396 325hp A/T A/C tilt wheel power window power top 12 bolt rear end. There are no docs for this car sheet metal and floors are very good condition I will email pics to anyone who is serious about this car. The 396 is date matched for the car not the original block email me at [email protected] or send me a PM 39,000.00 for car and all the parts this is a real Pace Car thanks Brian
Old 11-08-2008, 04:21 AM
MR-427 MR-427 is offline
Default Re: 1969 Camaro Pace Car Z11 396 A/T A/C
Brian..I cant believe you are selling this car. When I saw it last year at your shop it looked pretty good and you wouldnt part with it....Mike.
Old 11-08-2008, 08:14 PM
Old 11-08-2008, 08:23 PM
Old 11-12-2008, 06:49 PM
Here is a long list of parts that go with the car email I may have for gotten some parts thanks Brian
AIR CLEANER ASSY
OUTTER A/C BOX
FRONT BUMPER ASSY
REAR BUMPER ASSY
NEW WIPER MOTOR W/O HEAD LAMP WASHER
4 ORIGINAL TRIM RINGS
4 ORIGINAL CENTER CAPS
NEW ROSE WOOD STEERING WHEEL
R & L HOOD HINGES
FENDER SUPPORTS
A/C BRACKETS
ALT BRACKETS
SMOG BRACKETS
CRANK, WATER PUMP, POWER STERRING SMOG PUMP PULLEYS
WINDSHIELD WASHER5 BRACKET
RS HEADLAMP VACCUM TANK
NEW METRO DOOR WEATHER STRIPS
NEW HEATER HOSE KIT
NEW GM SS EMBLEMS
NEW GM 396 EMBLEMS
NEW HEADLAMP WASHER HOSE KIT
AM/FM RADIO NOT GREEN LIGHT
NEW GM 12 BOLT CLUTCH PLATES, SPRINGS, SEALS, YOKE
NEW PRESION GEAR 3.41 RATIO GEAR SET
NEW REAR SHACKEL KIT
NEW REAR LEAF SPRINGS
4 NEW GM REPLACEMENT SPIRAL SHOCKS
ROSE WOOD ASH TRAY ASSY
NEW ROSEWOOD RADIO DASH PLATES
NEW ROSE WOODL SIDE DASH BEZEL
NEWW 333 PIECE INTERIOR SCREW SET
NEW A ARM DUST SHIELDS
NEW FRONT END BOLT KIT
NEW CONSOLE LID
NEW HEATER CORE
NEW RT SIDE VISOR BRACKET
NEW FRONT BRAKE LINE HOSE KIT
NEW MASTER CYL BRACKETS AND LINES
USED MASTER CYL AND BOOSTER NEEDS RESTORED
2 NEW HEADLAMP VACUUM ACCUATORS
A/C BOX BOLT KIT AND LINE BRACKETS
NEW HEADLAMP VACUUM LINES
NEW COWL INDUCTION WIRING HARNESS AND RELAY
NEW REPRODUCTION POS & NEG BATTERY CABLES
NEW POWER WINDOW HARNESS DOOR BOOTS
NEW HEAD LAMP SWITCH
NEW METRO CONVERTABLE ROOFRAIL SEAL KIT
NEW METRO PILLAR SEALS
NEW FRONT COIL SPRINGS
NEW BIG BLOCK SHROUD
NEW GM GRILL
NEW GM TRUNK WEATHER STRIP
NEW AIR COND LINE KIT
NEW TRUNK LIGHT KIT
NEW PUI BELT MLDG KIT
272 BLOCK DATED B 14 8
063 HEADS DATED B 17 9 B 18 9
067 INTAKE DATED B 11 9
6223 CRANK
STOCK 396 RODS
7204 Q JET DATED 361 8
NEW STAINLESS STEEL FUEL LINE KIT
NEW STAINLESS STEEL BRAKE LINE KIT
COMPLETE BODY RUBBER SEAL KIT
