Old 11-09-2008, 02:56 AM
LITTLE TOMMIE LITTLE TOMMIE is offline
Default ORIGINAL STAMPING ON GLASS
does anyone know how they did the original stampings on all of the glass ( front, rear, and sides ) like the lof and dates, what was the process
thanks
TOM
Old 11-09-2008, 03:11 AM
deuce-less deuce-less is offline
Default Re: ORIGINAL STAMPING ON GLASS
i believe that the mfg. facilities used two different methods to "bug" the parts...
acid etching
beading of the logo or bug
Old 11-09-2008, 05:06 PM
-----OEM Glass uses the beading method. Very similar to sandblasting, just done way more carefully with different bead, etc...........Bill S
Old 11-09-2008, 10:36 PM
what did they use for stencils
Old 11-09-2008, 11:45 PM
-----I have seen them and they are just small stencils. I dont know what material they are made out of.......Bill S
Old 11-10-2008, 01:11 AM
anyone else know what they may be made of or how the cut them out. i know they chsnged the dates on them, i am tring to learn the process
Old 11-10-2008, 09:51 PM
most of the re-pop glass suppliers are using an acid touch system... the stamps they use can be made pretty inexpensively with the different dates that are required for their use.
the real question is, are they licensed to use the logo, especially on glass that is not OE
Old 11-11-2008, 01:59 AM
Kurt S Kurt S is offline
Some info under 'Marking Method' - http://www.camaros.org/glass.shtml
The Astro Vent logo was fired on!
Kurt S - CRG
