Old 01-27-2009, 10:32 PM
Zach Carter Zach Carter is offline
Default Brake Caliper Rebuilding/Restoring
Does anyone know where I can get the brake calipers on our 69 Biscayne rebuilt/restored?
Zach Carter
1969 Biscayne L72 M22 Real
1972 Nova SS-Former Drag Car
Old 01-27-2009, 11:33 PM
Default Re: Brake Caliper Rebuilding/Restoring
Jerry at CHP in Maryland.
Old 01-27-2009, 11:39 PM
clopo clopo is offline
I have had very good luck with Jeff Watts at Karps Power Brake Service. Great work and good people to deal with. [email protected] 909-985-0800 66 N. Central Ave. Upland, Ca. 91786
Old 01-27-2009, 11:40 PM
www.resleeve.com
Old 01-28-2009, 12:04 AM
69z28302 69z28302 is offline
I believe Lonestar Caliper can rebuild them.
www.lonestarcaliper.com
Mike
Old 01-28-2009, 12:48 AM
Thanks for all of the responses guys. I'll give these people a call.
Zach Carter
Old 01-28-2009, 02:22 AM
302moz 302moz is offline
If it is a 69 single piston caliper resleeving is a waste of money.Replace the piston and a seals for about 20 dollars from any parts store. Bead blast the inside of the caliper and use silicone brake fluid. The operating principals of a single piston caliper is the piston doesnt touch the wall. The piston rides on the square cut seal. John
Old 01-28-2009, 02:27 AM
m22mike's Avatar
m22mike m22mike is offline
Good advice...not that tough to reseal.
Mike
Old 06-02-2017, 02:40 AM
I havent looked at YOUTUBE (yet) but any further advice for the Removal and Install
of the two piece AC Delco kit for my 70+ Camaro calipers ???
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 06-02-2017, 03:16 AM
Ive already gone to YOUTUBE......so just need to DO IT myself !!!!
I will have caliper housings shot blasted but NOT the pistons .....or does it matter ???
For a driver/street car is KRYLON primer and Cast Blast aerosol OK or will it not hold up for long ??
Chuck Sharin
[email protected]
The Following User Says Thank You to CamarosRus For This Useful Post:
Slob44 (03-17-2018)
