Old 02-03-2009, 09:56 PM
subyman99 subyman99 is offline
Default z28 1969 pushrods, what to use?
i have a 69 z28 survivor, and the engine is all gm parts, including lifters and cam. What pushrods should i use? i see the "blue-tip" pushrods on ebay but i was wondering if there are any aftermarkets that are good or the same. thanks guys
Matt
1967 Z28 survivor Black original drivetrain
1968 Z28 survivor white 40k miles
1969 Z28 survivor Rally Green 60k miles
1969 Z28 survivor Rally Green 20k miles
1969 Yenko Camaro Lemans Blue -muscatell sold new, second to last yenko made
1969 Berger copo original paint 240 miles
Lots of 67-72 Chevrolet trucks
Old 02-04-2009, 08:34 PM
Jerry@CHP Jerry@CHP is offline
Banned
Default Re: z28 1969 pushrods, what to use?
We use a very simliar push rod to the blue tip GM's and they are actually stronger than the GM push rods. $120 a set plus shipping. Have a darker heat treated look. Have used them in dozens of 302s that I've built over the years.
Jerry
Old 02-04-2009, 09:05 PM
beater68427 beater68427 is offline
Matt
Call Compitition Products in Oshkosh WI 800-233-0199 I would use part number #1400 4130 material .065 wall 1pc swedge end much stronger than factory price is 52.95 you could go to a .080 wall but not needed in your application, hope this can help.
Old 02-06-2009, 07:10 AM
Banned
We have had bad luck with the swedged tip and ball tip push rods in 302 engines. On at least two dyno tests, they have bent or broke over 6000 rpm.
I have had great success with Comp Cams push rods. They cost more but are one piece seamless and made in the USA. .065" wall and good over 8000 rpm. This is what I use in my Stock Eliminator engines and none have ever failed. Many of the less expensive push rods are made in Taiwan. Just some food for thought.
Jerry
Old 02-06-2009, 04:46 PM
Jerry
The number I gave him was a howards not import they sound like the same pushrod, I was mistaken when I said swedge tip they are 5/16 and no reason to be swedge, Im use to running 3/8 and they have to be swedge, I agree I would not ever run a ball end type pushrod on anything. As far as Howards products I have never had any problems and have purchased Hundreads of sets without failure, now I do not specialize in 302's probably never will, I build engines in a different form than most use here.
Old 02-06-2009, 06:20 PM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
Why not use GM pushrods to keep your GM car all GM? GM performance parts has very good pushrods for your Z.
1968 Z/28 34,000 mile, born with engine and trans, Shipper, California car, Fathom Blue, deluxe interior, M21, 3.55 Posi
1962 Oldsmobile Jetfire, Factory all Aluminum V8 Turbocharged and Methanol Injected TURBO ROCKET engine, 4 speed Hydramatic, 4 link rear suspension, 3.36 Anti-Spin differential, California car, PS, PB, PW, AC, Jetfire 2 option package.
Old 02-06-2009, 06:44 PM
Banned
The new GM push rods will not hold up if you drive the car and rev it up to 6000-7000 rpm. Especially a 302. If it's a trailer queen, then they're fine.
The hardened blue tips have been long gone.
Jerry
Old 02-06-2009, 06:51 PM
You'd have to think that technology has improved in the past 30 years...
Old 02-06-2009, 08:16 PM
Banned
Bruce,
In Stock Eliminator, the best rocker arms to use are still the original "O" stamped rockers. All of the heat treated Manleys, Cranes, etc eventually break in the 7000-8000 rpm range. They do not hold up like the originals. I can't figure that one out either.
Jerry
Old 02-07-2009, 12:42 AM
See...what the heck do I know?
